Thread: DAB Problem: No sound / Ensemble 1 - SOLUTION
Results 1 to 10 of 11
  1. Thumbs up DAB Problem: No sound / Ensemble 1 - SOLUTION
    May 2013
    Cheshire
    11 Post(s)
    I've experienced a DAB issue twice in quick succession. The first time it seemed to resolve itself, and yesterday, as it happened again, I decided to investigate a bit further.
    The symptoms:
    When selected DAB, all stations are displayed, but there is no sound. The is an additional entry at the bottom of the list indicating Ensemble 1, with a "no speaker" sign (see attached).
    Rebooting MMI (long press on big button + top right + menu) does not clear it.
    Every other source (including FM / LW / MW) works fine, which indicated to me it was less likely to be a reception issue.
    SOLUTION:
    I found a useful youtube video with someone having this problem on an A5. The solution is strangely simple and impossible to find...
    REMOVE the USB charger from the 12V plug in the front central storage unit!
    Hope this helps!
    63 reg Ibis White A6 2.0 TDI SE Multitronic, Tech pack, folding mirrors, rear view camera, heated seats.
  2. Re: DAB Problem: No sound / Ensemble 1 - SOLUTION
    Mar 2014
    Edinburgh
    235 Post(s)
    Probably related to electronic interference.
    In my old car if I had the phone charger in there will be static noise coming from the stereo and as soon as I unplugged it everything was fine. The charger was a cheapy eBay special. Got a better charger and that cured it.
  3. Re: DAB Problem: No sound / Ensemble 1 - SOLUTION
    May 2013
    Cheshire
    11 Post(s)
    Rather frustratingly (and annoyingly) the (intermittent) problem has come abck, without a USB charger in the 12v :/
    So not quite solved after all.
  4. Re: DAB Problem: No sound / Ensemble 1 - SOLUTION
    Aug 2009
    Near Lanark
    21 Post(s)
    I get that occasionally.
    I think it's dab reception issue. Other frequencies work ok for me too.
    Sent from my SM-G920F using Tapatalk
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  5. Re: DAB Problem: No sound / Ensemble 1 - SOLUTION
    Mar 2014
    Edinburgh
    235 Post(s)
    Could it be an issue with the aerial? The shark fin aerial is prone to get leaks and corrode away inside then stops working.
    I know some have had problems with that from gps to radio not working.
  6. Re: DAB Problem: No sound / Ensemble 1 - SOLUTION
    Aug 2009
    Near Lanark
    21 Post(s)
    I suppose it could be leaks although there's no evidence inside. And when I last scanned my car I had no errors on vcds
  7. DAB Problem: No sound / Ensemble 1 - SOLUTION
    10 Post(s)
    Do you have no USB chargers plugged in at all? I’ve had this in quite a few other cars (non Audi too), DAB reception is always flaky for me if I’m using any usb chargers at all (charging via the MMI input always works fine)
  8. Re: DAB Problem: No sound / Ensemble 1 - SOLUTION
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Do you have any hardwired 12v to 5v converters that could be used to power dash cams or USB devices? I had one of these in a previous car and it knocked out all DAB and FM reception. I had to use a ferrite clip to recover the FM & DAB reception.
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  9. Re: DAB Problem: No sound / Ensemble 1 - SOLUTION
    May 2013
    Cheshire
    11 Post(s)
    Well, nothing plugged in, and it does it sometimes.
    I have read issues with the aerial could cause this, but the GPS works fine, and so do all other non digital radio frequencies.
    I don't live in the stick, so would be surprised if there were issues with the emission at all, without making any noise on the internet.
    It is regular, but infrequent, so I'll live with it I guess.
  10. Re: DAB Problem: No sound / Ensemble 1 - SOLUTION
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by Olio View Post
    GPS and phone aerials are on roof but the radio Aerials (DAB and FM are seperate) are in either the rear (saloon) or side (Avant) window. Could be the aerial amplifier playing up or a poor connection between lead and where it connecs with the glass
  1. A Solution to the Jacking Problem
    By djgilson in forum General
    Last Post: 01-09-2014, 07:52 PM
  2. Anyone got a solution to "emissions garage" problem?
    By dawndriver in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-04-2010, 04:36 AM
  3. Replies: 12
    Last Post: 14-08-2009, 12:42 PM
  4. A6 Avant - Rear washer jet problem and solution
    By paultyson in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-01-2009, 01:59 PM
