Thread: A4 2.5 tdi Oil Sensor.
  1. A4 2.5 tdi Oil Sensor.
    Feb 2007
    The oil sensor light has come on this morning on the wifes 02 2.5 tdi sport. Levels fine. can anyone please help?!
  2. Re: A4 2.5 tdi Oil Sensor.
    How long is it since u changed ur oil?if you are sure the oil pressure is ok and the oil quality is ok, take one of the battery terminals off for about 30 secs, before replacing it (make sure your ignition is switched off when u do this) and see if the light goes out
  3. Re: A4 2.5 tdi Oil Sensor.
    133 Post(s)
    1986 Post(s)
    Hi Steve and welcome. Was it pressure or level and has it gone out now you have checked the level?
  4. Re: A4 2.5 tdi Oil Sensor.
    Feb 2007
    Quote Originally Posted by kenney View Post
    Good man!! Worked a charm. The main prob with this car is under use.
    Serviced in June and she's only done 400 miles since....
    But great advice and once again many thanks
  1. Map sensor anyone?.
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-10-2007, 09:18 PM
  2. MAF Sensor - A3
    By Niklock in forum Archive posts
    Last Post: 06-10-2007, 06:32 PM
  3. Thrust Sensor same as Map Sensor?
    By whistleblower in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2007, 06:03 PM
  4. MAF sensor
    By NIgolf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-04-2007, 12:18 PM
  5. MAF Sensor
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2007, 11:09 AM
