Thread: Weird RNS 510 problem.
Results 1 to 10 of 15
  1. Question Weird RNS 510 problem.
    Aug 2017
    kotka, Finland
    6 Post(s)
    Hi!
    I have quite annoying case. Bought RNS 510 (1T0 035 680 C) from ebay...
    Installed it as soon as i got it, plugged the quadlock, and only the fan behind the unit started.. had long conversation with seller, and decided to send it back.
    Seller sended video, when he tested it to hes passat, where its originally from. Works flawlessly. And now i have RNS back again, but situation is same, only fan running.
    I had RCD 510, and tried to upgrade to RNS. Car is passat b6, 2010.
    RNS510 is from transporter 2012.
    Anyone got any idea why RNS works on transporter, but not on Passat?
  2. Re: Weird RNS 510 problem.
    Jul 2007
    glasgow
    35 Post(s)
    is it not coded ?? So putting the radio back in original car & it works fine
    the radio should check with the car that the security code in the car matches with the radio, to try and stop car thieves
    Try this How To Find Your VW Radio PIN Code And Get Out Of SAFE Mode - YouTube
  3. Re: Weird RNS 510 problem.
    Aug 2017
    kotka, Finland
    6 Post(s)
    I have the code, but never get so far to put code to radio. When i plug the quadlock to unit, just the fan behind the unit starts. but when the unit putted back to transporter where its originally from, starts just by pushing volume button.
    Just wondering why it works on transporter, but not on my passat. Cause i have tried another RNS to passat, and it works as it should. Weird.
  4. Re: Weird RNS 510 problem.
    Mar 2014
    Northampton, United Kingdom
    Quote Originally Posted by koodi View Post
    You sure the seller isn't trying to scam you and can actually prove that in the video he sent you he is using the exact same unit and not another working one?
  5. Re: Weird RNS 510 problem.
    Aug 2017
    kotka, Finland
    6 Post(s)
    Pretty sure it the same unit. First on video he film the newspaper, that was same date when courier gave the unit back to him. Also on top of unit were same tapes and code.
  6. Re: Weird RNS 510 problem.
    Mar 2014
    Weird, wondering if Digital Radio needs enabling on your car then mate.
    That can be done via VCDS, could do it for you but as far as I understand you are from Finland so...
  7. Re: Weird RNS 510 problem.
    Aug 2017
    kotka, Finland
    6 Post(s)
    Why didnt 1T0 035 680 P RNS510 needed any coding, well it needed PIN obv. But nothing else.
    I have VCDS, but couldnt reach the radio nor navigation with it. Confusing. Maybe better to give it to someone who has any intresses to solve this shiet.
  8. Re: Weird RNS 510 problem.
    Mar 2014
    Can you reach radio module via VCDS with the old unit plugged in?
  9. Re: Weird RNS 510 problem.
    Aug 2017
    kotka, Finland
    6 Post(s)
    Yes i can. Called to vw dealer yesterday, they said: "unit just nit work on your passat".
    How clear answer is that?!?
  10. Re: Weird RNS 510 problem.
    Mar 2014
    There might be multiple reasons here mate. But VW definitely haven't provided a good enough answer
    The RNS510 that you are connecting has a newer firmware version of some sort which is not compatible with your canbus.
    The new unit is from a newer car which could mean it has upgraded hardware as well as hardware firmware (they have Software Firmware (SW) and Hardware Firmware (HW))
    Some of the newer hardware components might not simply be compatible with your ecu or any other component in your car.
    I understand that above is not helping but at least it explains possible reasons.
    If you have access to another RNS510 then compare their SW and HW and see if they are different, if they are then it might somehow be related to that.
    You can then also try to reflash the firmware to a lower version perhaps (if possible at all) and hope that it will fix your problem.
  1. Here's a weird odd problem...
    By NewAudi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-06-2017, 02:29 PM
  2. Replies: 1
    Last Post: 24-01-2017, 03:43 PM
  3. Weird problem....
    By matrixpt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-03-2014, 10:40 PM
  4. weird air con problem
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 14-05-2009, 10:10 AM
  5. Weird problem on a 1.6 FSI
    By cazanradudaniel in forum Golf MK4 - 1999 - 2004
    Last Post: 14-08-2008, 07:45 PM
