Thread: Anyone have experiences with ECU Problems ?
  1. Anyone have experiences with ECU Problems ?
    Apr 2012
    leicester england
    I have a 2006 Audi A4 B7 2.7 TDI which has randomly cut out on me whilst driving a few times over the months. I have had it scanned twice by an Audi Specialist using VAGcom and the codes have come up as all injectors in bank A and bank B (V6 engine) are faulty and also all glow plugs.
    All injectors, glow plugs and wiring upto the ECU has been checked and no fault can be found so the have determined that it can only be a ECU fault thats causing this.
    Ive browsed online and ECU repair places charges around £250.
    A new unit from Audi would cost £750 inc VAT. Are these plug and play or would a new unit have to be coded/programmed by Audi ?
    Anyone had successes with ECU repairs ?
  2. Re: Anyone have experiences with ECU Problems ?
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    You would need a new ecu coded to your vehicle. I would prefer to do more diagnostics before sending ecu away, or even worse, ordering a new one.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Anyone have experiences with ECU Problems ?
    Aug 2014
    Slovenia
    Better double check the injector pulses with scopemeter and glow plugs voltage and current. Also posting fault codes, engine code would be helpful.
    AUDI A4 B8 2.0TDI 2010 100kW CAGB
  4. Re: Anyone have experiences with ECU Problems ?
    Apr 2012
    leicester england
    Quote Originally Posted by turbozob View Post
    Codes on 1st scan was,
    005659 - GLOWPLUG FOR CYLINDER 2 (Q11)
    P161B - OPEN CIRCUIT
    SAME FAULT ON ALL PLUGS
    004162 - SUPPLY VOLTAGE TO INJECTORS
    P1042 - CIRCUIT MALFUNCTION - INTERMITTENT
    The second time it cut out the scans came back as,
    005648 - INTERNAL CONTROL MODULE SUM ERROR
    004162 - SUPPLY VOLTAGE B FOR INJECTORS CIRCUIT MALFUNCTION
    004160 - SUPPLY VOLTAGE A FOR INJECTORS CIRCUIT MALFUNCTION
    ALL GLOW PLUGS SHOWING OPEN CIRCUIT
    The Engine code is BPP, all wiring from injectors to ECU has been checked also the all glow plugs and nothing is wrong them.
    After the codes are cleared they don't reappear until it cuts out again.
  1. Passat electrical and rattle problems - your experiences?
    By dlangmead in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 04-01-2017, 02:01 PM
  2. Experiences of the 3.0 TDI vs 2.7 TDI
    By Dans in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-09-2012, 10:45 AM
  3. DSG Experiences
    By Jo Illingworth in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 20-07-2012, 01:16 PM
  4. Chipping Experiences?
    By alfapersius in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-05-2010, 10:59 AM
  5. Your experiences
    By Brett Thorpe in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-11-2007, 12:25 AM
