Thread: Right Front Park Sensor Replacement
  1. Right Front Park Sensor Replacement
    My parking assist isn't working. VCDS scan shows fault with right front g252 sensor. Is is right when looking at the car or right from looking out the car? i.e. is driver side?
    The drivers side sensor looks to have been replaced before as it hasn't bee sprayed to match.
    How easy is this to swap? Does the bumper need to come off and if so how hard is that?
  2. Right Front Park Sensor Replacement
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    The position it is always when staying in the car. If you have right drive wheel than in your case it's driver's side. If you have left drive wheel it is passenger side.
    It's very easy to change it. Just don't push too hard so you don't break something else)
  1. How To Front parking sensor replacement?
    By Tricky1942 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-02-2013, 10:51 AM
  2. Front ABS Sensor Replacement
    By dickturpin in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2011, 07:00 PM
  3. Front right ABS sensor replacement
    By peterdelphi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-11-2010, 09:55 PM
  4. Park Distance Control sensor damage?
    By godfried in forum Audi A3 - Archive Topics
    Last Post: 03-11-2008, 12:33 PM
  5. How To Remove a reverse park sensor?
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2008, 12:01 PM
