Thread: Electric Hand break light on
Results 1 to 10 of 10
  1. Electric Hand break light on
    Aug 2017
    USA
    After I changed the rear break pads the electric Hand break light keeps going off /on.
    What would you recommend doing to get it to work correctly?
    Thank you
    Rad
    Audi A4 2.0 year 2010
    Sent from my LG-H918 using Tapatalk
  2. Re: Electric Hand break light on
    134 Post(s)
    2007 Post(s)
    How did you put the calipers into service position?
  3. Re: Electric Hand break light on
    Aug 2017
    USA
    The same way I took them out. Pushed the pistons in and then put the calipers back and screwed the 2 screws back.
  4. Re: Electric Hand break light on
    Dec 2014
    Bedford
    42 Post(s)
    Oh dear.
    1 1 0
  5. Re: Electric Hand break light on
    Aug 2017
    USA
    Did I do it wrong????
  6. Re: Electric Hand break light on
    134 Post(s)
    2007 Post(s)
    Quote Originally Posted by radshaykho View Post
    Oh did you..........
  7. Re: Electric Hand break light on
    Aug 2017
    USA
    Thanks for the help!!!
  8. Re: Electric Hand break light on
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    read this regarding service position, if you didn't do this, then chances are the calipers are now damaged and likely need replacing.
    Working on the Electro-Mechanical Parking Brake (EPB) - Ross-Tech Wiki
  9. Re: Electric Hand break light on
    Aug 2013
    18 Post(s)
    Did you use this following method?
  10. Re: Electric Hand break light on
    Aug 2017
    USA
    Thank you very kindly for your help and support
    Rad
  1. Please Help Hand break no auto release after DMF bearing replaced.
    By P Smiddy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2014, 07:47 PM
  2. Third break light
    By ajmartins in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-03-2011, 03:05 PM
  3. Towing a Carvan with Auto Hold & Electric Hand Brake? Opinions Please??
    By RickT in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-01-2010, 10:50 PM
  4. break light
    By tab99_uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-12-2009, 04:14 PM
  5. faulty electric hand brake on my A6
    By brakeman in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-09-2009, 01:03 PM
