Thread: HELP PLEASE - Engine Keeps Cutting Out!
Results 1 to 10 of 11
  1. HELP PLEASE - Engine Keeps Cutting Out!
    Jun 2012
    Shaftesbury, Dorset, England
    Hi All,
    I've a real problem and would really appreciate some help.
    The short story is:
    Randomly, my engine just cuts out totally, no warning lights on dash such as ESP, Glow Plug, or ECU, that usually come on when a problem occurs. I can start my car and more often than not, it will drive ok, but then just cuts out. If I turn off and re-start it runs for about a minute or two, then stops. this goes on and on.
    Ironically, but probably totally coinsadentally, if I turn the AC off, it seems to keep going, but if I then turn the AC back on once the car is running, it keeps going!
    The long Story is(but bulleted)
    I got this car in June 2010 at 60,000 miles. I've took it to my usual dealer for a warranty check over and they said it was 100%, even though I said I thought it was down on performance and fuel ecconomy was poor. They have always said there was no problem, but then I got the Injector recal in the new year of 2012. This seemed to solve all the problems of poor performance, low fuel ecconomy (37MPG ave) and poor starting. Then it started to run rough again and seem to have a miss-fire and sometimes fealt in traffic it was running out of power, but never stopped. The dealer still said there was no problem but when it was serviced a few weeks ago (approx 110K miles), they replace a cap or valve as they said there was a code stored for low turbo boost. Now it has this cutting out problem!
    I'm wondering if it is something to do with any of the following:
    AirCon problem
    Key / imobaliser problem (altough I've tried both keys and same issue)
    Fuel pump problem
    EGR
    Turbo
    Or, is it just a cold temp running sensor?
    I'm currently awaiting the dealer to call me back after trying to get some Tech help from Audi H/O
    Mycar is:
    A4 B7 June 2007
    2.0 TDI 170
    S-Line
    SE
    Quattro
    112K miles Full Dealer Service History
    Any Help would be greatfully appreciated.
    Dave
  2. Re: HELP PLEASE - Engine Keeps Cutting Out!
    mostly in the garage
    you really need to check if there are any fault codes stored again otherwise it'll just be guesswork....
  3. Re: HELP PLEASE - Engine Keeps Cutting Out!
    Jun 2012
    Thanks for the response.. Yes, That's my thoughts & understanding too.......... Trouble is, is that I've been in the motor trade all my life (since 84) and was originally on the spanners and now in parts & manufacuring and I am starkly aware that dealers no longer employ mechanics as the overall manager at my local dealer had to conceed today! Unless Audi send them a note or thier computer tells them there is a problem, they are lost..... ;-)
    I'm currently waiting for them to come pick it up but I'm hoping to get the codes read tomorrow morning before they have it as I no longer trust the dealers, but as they've serviced it for the last 2 years including a few weeks ago, I'm hoping they will take some rsponsability, especially as I've been telling them there's a problem for months!
  4. Re: HELP PLEASE - Engine Keeps Cutting Out!
    May 2007
    knee deep in clunge
    14 Post(s)
    lol rubbish
    god i wish some one at audi would send me a note how the f@@k have i survived for 20 years
    vag diagnostics, retrofits and general repairs
  5. Re: HELP PLEASE - Engine Keeps Cutting Out!
    Jun 2012
    Quote Originally Posted by a8 tech View Post
    lol rubbish
    Not sure what you think I've stated is rubbish, but it sonds like you are an experienced guy, and not a dealer technition.
    It's the proper mechanics/Technitions like you sound you are that can think problems through for themselves with common sense and experience...... In my experience, it's the "Dealers" that lack the intuition to diagnose unless the have a bulliten from the manufacturer, or the Diagnostics system telling them.
    That asside..... do you have any idea in your experience what my problem could be?
    May 2007
    knee deep in clunge
    14 Post(s)
    I am a fully trained dealer master technician and yes I do
    Post a scan
    It's likely to be engine speed sender or voltage supply relay to the ecu
    Sent from my iPhone using
    My fat fingers
    May 2007
    knee deep in clunge
    14 Post(s)
    Or the fuel is contaminated with soot
    Drain the filter and inspect the fuel
    My fat fingers
  8. Re: HELP PLEASE - Engine Keeps Cutting Out!
    Jun 2012
    Hi A8 Tech,
    Thanks for your further replies.
    I fill up with fuel usually 2 - 3 times a week, so the system is clean, apart from the obvious possabillity of dirty fuel going in.
    As for the other possible problems.....
    Is it at all plausable that any of these issues could have been caused by either:
    A: something the dealer technition did whilst fitting the new injectors or the V03G 129 061C Vacum unit (this was suppossed to have fixed all the problems when it was serviced a few weeks ago!)
    B: as a result of the vehicle being driven for 40,000 plus miles with the defective injectors when the dealer couldn't find a problem until the recall
    It seems to be something shutting the fuel system down, but I appreciate it's hard to pinpoint these issues sometimes............ but it's all too much of a coincidence!
    I'm going to have the vehicle read for fault codes by an independant VAG specialist (originally VAG Master Technition) to see if I can get a view before the felaership comes and picks it up.
  9. Re: HELP PLEASE - Engine Keeps Cutting Out!
    Jun 2012
    The other thing I thought it might had been was a problem with my ignition key, but it still does it with my spare, or a problem with the vehicles imobaliser.................. A bit like certain vehicles that if you perform a battery change, you have to go through a sequence of re-programming the car or it will start up, but then just cut out after a matter of seconds to prevent theft. I n most of these cases, you can perform the reset by simply locking and un locking the car via the fob.
    Also.......... and this is a interesting one..................................
    As you have been able to throw up a few suggestions to the possible problem, how come it took most of the day for the dealer to call me to say that they had all had a think and a chat abou tmy problem, but were totally lost as to what it could possibly be!! ;-)
  10. Re: HELP PLEASE - Engine Keeps Cutting Out!
    May 2012
    Norfolk
    Back when dinosaurs ruled the earth I had an Alfa 75 Veloce which developed a problem very similar to your A4. The cutting out would occur without warning (therefore potentially dangerous) and only when the engine was hot. After much investigation it turned out to be a relay that powered up the Magnetti Marelli ECU (and so much along the lines of what A8 Tech suggested).
    Something inside the relay obviously went open-circuit when it got too hot. A simple and cheap change and I had no problems afterwards.
    Hope yours is something similar.......
  1. Please Help Engine cutting out
    By HelenButler in forum Golf Plus
    Last Post: 09-05-2020, 01:18 PM
  2. Please Help Engine cutting out
    By Rob1uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2011, 10:17 PM
  3. Please Help Engine cutting out
    By Henry9090 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-02-2011, 08:53 AM
  4. Question Engine cutting out
    By tinnion in forum Golf MK3 - 1993 - 1999
    Last Post: 04-12-2009, 03:06 PM
  5. Engine cutting out!
    By zeroseven in forum Golf MK4 - 1999 - 2004
    Last Post: 20-11-2008, 02:06 PM
