Thread: Lambda P2196 - 000 - Signal too High (Rich) and
  1. Lambda P2196 - 000 - Signal too High (Rich) and
    Feb 2015
    United Kingdom, Oxford
    Hi all,
    All help gratefully received.
    2008 Passat 2.0 140HP common rail diesel, I believe a CBA engine on about 130K miles.
    My tale of woe started 2 weeks ago when the engine fault light indicated a problem. So I finally bit the bullet and purchased a VCDS unit. First fault log below.
    After a bit of forum research, I ordered and fitted a new VDO throttle body. I cleaned the EGR while it was off.
    Disassembling the old throttle body out of curiosity I found the gear box and motor of the unit full of thick black oil, presumably leaking through the butterfly bearing over time. So not surprised it was faulty.
    Fitting the new throttle body seems to have cured the P2102 signal low fault as that has not happened since.
    But the car is now showing the second faults below - Still have the lambda fault but now also have: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    After fitting the new throttle body the car was OK for about 500 miles then showed the fault and went into limp mode. Stopping and re-starting it runs fine for a while. But now after tinkering some (Cleaning the lambda sensor and I replaced the gasket between the exhaust gas return pipe and the EGR as i re-used the old one) to try and fix the errors, it seems to run OK for a mile or so then shows the fault and goes into limp mode.
    Questions:
    Could the two current faults - Lambda sensor and Boost pressure be connected?? The Lambda fault seems to have been there since May
    I've had the lambda sensor pickling in vinegar for 24 hours to try and clean it, but its made no difference - should i just replace it??
    Any ideas what could be causing the Boost pressure problem - could it be something to do with changing the throttle body?
    I found a post about calibrating the throttle body, but the block numbers for VCDS given in the post didn't work so i haven't done that - does it need calibrating?
    Many thanks in advance
    Regards
    Paul
    First set of faults
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 FN HW: 03L 907 309
    Component: R4 2,0L EDC G000SG 2643
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 84224 802 739910
    VCID: 76B6EFF824C052D7075-8022
    5 Faults Found:
    008598 - Oxygen (Lambda) Sensor B1 S1
    P2196 - 000 - Signal too High (Rich) - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 92
    Reset counter: 255
    Mileage: 203622 km
    Time Indication: 0
    Date: 2017.05.11
    Time: 06:50:46
    Freeze Frame:
    RPM: 2001 /min
    Speed: 70.0 km/h
    Lambda: 53.7 %
    Mass Air / Rev.: 535.0 mg/str
    (no units): 23.71
    (no units): 16.0
    Voltage: 0.975 V
    008450 - Throttle Valve Actuator Module (J338): Motor Circuit
    Motor Circuit
    P2102 - 000 - Signal Low - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 19
    Reset counter: 255
    Mileage: 208375 km
    Time Indication: 0
    Date: 2017.07.13
    Time: 20:02:18
    Freeze Frame:
    RPM: 1794 /min
    Speed: 77.0 km/h
    Load: 25.5 %
    Load: 15.3 %
    Lambda: 100.2 %
    Mass Air / Rev.: 670.0 mg/str
    Temperature: 89.1°C
    Second set of faults:
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 210047 km
    Time Indication: 0
    Date: 2017.08.06
    Time: 15:38:40
    Freeze Frame:
    RPM: 1357 /min
    Speed: 47.0 km/h
    Lambda: 42.6 %
    Mass Air / Rev.: 470.0 mg/str
    (no units): 25.40
    (no units): 16.0
    Voltage: 0.975 V
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 210049 km
    Time Indication: 0
    Date: 2017.08.06
    Time: 15:40:28
    Freeze Frame:
    RPM: 2277 /min
    Speed: 98.0 km/h
    Absolute Pres.: 2346.0 mbar
    Absolute Pres.: 1224.0 mbar
    Temperature: 28.8°C
    Mass Air / Rev.: 545.0 mg/str
    Lambda: 12.6 %
    Readiness: 0 0 0 0 0
    Sunday,06,August,2017,17:08:54:30454
    VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
    Data version: 20170721 DS276.2
    Ross-Tech: Home
  2. Re: Lambda P2196 - 000 - Signal too High (Rich) and
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Hi Paul, my son's Passat, same year & engine as yours had the same original fault a few years ago.
    The throttle valve was full of oil just like your one.
    I replaced it & it totally cured the problem, no setting up required with the new valve.
    I have a Passat estate, same year & engine & have had the same Lambda fault, I tried cleaning but no success.
    It caused no detectable loss of power or drivability while faulty, I replaced it with a second hand unit from a breakers & had no further problems.
    So the problem you have been left with seems a bit unusual.
    It sounds like the turbo isn't boosting enough or some pressure is being lost.
    Maybee you have a leak somewhere in the pipework from turbo to intercooler to inlet, sometimes hard to find as very low bost pressure when the car is at a standstill.
    The other thing that springs to mind is that when the throttle valve fails it stops the DPF from regenerating.
    If that gets blocked it will reduce exhaust flow, so low boost from the turbo.
    It should have regenerated itself by now but you could try a forced regen now you have VCDS.
    Hope the above might throw some light on your problem.
  3. Re: Lambda P2196 - 000 - Signal too High (Rich) and
    Feb 2015
    Thanks for the input Philip. Looks like 3 separate faults then, although I still can't help thinking the boost pressure has something to do with me changing the throttle valve. Not a big believer in coincidence!
    Will replace the Lambda sensor, at least i hope i can clear another fault...
  4. Re: Lambda P2196 - 000 - Signal too High (Rich) and
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    It's a diesel and does not have a throttle valve. The unit you are talking about is the antishudder flap unit. It opens under motor power when the engine is started. It slams shut under spring pressure when the engine is shut off to prevent further intake thus eliminating shake / shudder caused by engine overrun.
    The P0299 is indicative of a vacuum leak, failed N75 solenoid valve or failed turbo actuator diaphragm or sticking turbo VNT mechanism causing under / over boost and limp mode. Might be coincidental to the antishudder flap issue. Some engines also have a motor driven or vacuum actuated flap unit inside the intake manifold (swirl flaps). This motor on the electrical actuated version is also prone to failure as it has plastic gearing which often wears out or breaks not to mention issues with the flap mechanism itself. Codes however usually refer to the V157 motor (even when it has a vacuum actuation method!) or Inlet Manifold Runner control deviation.
    I see from your other thread that it was the actuator diaphragm so no need for further comments.
    Mad Mitch
  1. Android and MMI high - no phone signal AFTER leaving car?
    By mikenott in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-12-2013, 01:06 AM
  2. Please Help 2005 Polo 1.4 BKY - LTFT High, Running Rich, MPG down! O2 sensor reading?
    By Rob69 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-03-2013, 09:56 PM
  3. Emission failure - Lambda too high and HC too high on idle
    By Sam Russell in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-11-2011, 04:59 PM
  4. Question Mk IV 4 motion 2.8 Lambda sensor signal
    By knowlden in forum Golf MK4 - 1999 - 2004
    Last Post: 18-11-2010, 06:00 PM
  5. No Signal from lambda probe Mk3 Golf VR6
    By deyres in forum Golf MK3 - 1993 - 1999
    Last Post: 14-03-2010, 05:45 AM
