Thread: 2.0tdi bkd ml5 golf juddering badly
Results 1 to 9 of 9
  1. 2.0tdi bkd ml5 golf juddering badly
    Jul 2017
    Hi everyone I'm new here so don't know if this is in the right section or not but I'm having really bad problems with my golf 2005 2.0tdi gttdi 140,
    What's happening is when I'm driving the car at engine temperature there is a bad judder between 1000-2500 revs and sometimes just cuts out, this happenes in all gears and I've been to several garages and they all have said something different! The car runs beautiful when cold but as soon as the engine gets to 90degrees it's judders splutters and kangaroos, and then on the odd occasion it will cut out and the glow plug light will flash and say engine garage fault,the eml light is never on but I've had it plugged in and it's giving a code p0726 as a pending code? Can someone point me in the right direction of getting this sorted please
  2. Re: 2.0tdi bkd ml5 golf juddering badly
    131 Post(s)
    1976 Post(s)
    That code suggests the engine speed sensor is faulty and this is a known issue. Unfortunately these are evil to replace as firstly the oil filter assembly must be removed and the the hex cap screw for the sensor released and this has to be done at an angle using a ball ended (usually 5-mm) hex key.
    If the head of the screw rounds out, the only solution is gearbox out and clutch/flywheel off and if the sensor ring gets damaged that is sump off and a special very expensive jig to re-install the seal in its correct position. It is a job we dread doing.
  3. Re: 2.0tdi bkd ml5 golf juddering badly
    scotland
    39 Post(s)
    Why do they have to change tried and tested designs, clearly this isn't because it's better.
  4. Re: 2.0tdi bkd ml5 golf juddering badly
    131 Post(s)
    1976 Post(s)
    Quote Originally Posted by calum View Post
    higher resolution signal for more accurate engine management than the old 60-2 method
  5. Re: 2.0tdi bkd ml5 golf juddering badly
    scotland
    39 Post(s)
    That's fair enough, progress and all that but why integrate it with the rear crank seal, just seems like madness to me.
  6. Re: 2.0tdi bkd ml5 golf juddering badly
    131 Post(s)
    1976 Post(s)
    It is the same technology as current ABS speed sensors and uses a ferrous ring, it is a good question WHY which I can't answer but my guess is build cost, repair cost ones well down the list.
  7. Re: 2.0tdi bkd ml5 golf juddering badly
    131 Post(s)
    1976 Post(s)
    I will see if I can find a VAG Self Study Program that explains it, there should be a few that cover the principle.
  8. Re: 2.0tdi bkd ml5 golf juddering badly
    Dec 2014
    Bedford
    42 Post(s)
    Think its in the introduction to the bkd 140 engine that ssp
  9. Re: 2.0tdi bkd ml5 golf juddering badly
    scotland
    39 Post(s)
    It's the fact that there is so much more work involved IF the sensor won't come out. How many garages would also advise a new clutch when the gearbox is out anyway. It would be prudent but not everyone with a ten year old
    + car would be willing or even able to throw more money at it due to a pennies part that's badly designed.
  1. 2010 A3 2.0TDI Common rail jerking badly HELP!
    By r4vvm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-01-2017, 10:15 PM
  2. GT TDI140 Juddering idle and shaking badly when engine is under load.
    By simon rampton in forum Golf MK5 - 2004 - 2009
    Last Post: 26-06-2015, 05:23 PM
  3. Please Help PD 150 struggling to start and then juddering badly at idle......
    By Jonny88 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-08-2012, 10:09 AM
  4. gt tdi 115 brakes juddering really badly
    By akiff in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2008, 11:25 PM
