Thread: Misfiring Vw Golf Mk4 Help!
Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 110
  1. Re: Misfiring Vw Golf Mk4 Help!
    #81
    The idle speed of my AUM is about 720rpm. If the throttle body was dirty would it be more inclined to idle faster than recommended rpm?
    I have and ultrasonic cleaner and would like to try cleaning the throttle body with it, if it's not too involved getting it off the engine.
    From your diagram, could you show me where it is. Also, would I need a new gasket for refitting?
    Your advice is much valued.
    Thanks again.
  2. Re: Misfiring Vw Golf Mk4 Help!
    #82
    131 Post(s)
    1979 Post(s)
    The throtle body is 27 on item 24 (inlet manifold) and after cleaning will have to be set up.
  3. Re: Misfiring Vw Golf Mk4 Help!
    #83
    Thanks for the throttle body locacation. If I take off the throttle body will I need a new gasket or are they reusable?
    Also, I have an Autel VAG405 scan tool. Would I be able to reset the throttle to the TB with it or does it need to be taken to a VW service station exclusively, to have the job done?
  4. Re: Misfiring Vw Golf Mk4 Help!
    #84
    131 Post(s)
    1979 Post(s)
    Does your scan tool have a "Basic Settings Group 04" function?
  5. Re: Misfiring Vw Golf Mk4 Help!
    #85
    No it doesn't appear to have that.
    On the main menu it's :-
    1)VW/AUDI
    2)OBDII/EOBD
    3)OIL RESET
    4)System Setup
  6. Re: Misfiring Vw Golf Mk4 Help!
    #86
    131 Post(s)
    1979 Post(s)
    What is under group 1?
  7. Re: Misfiring Vw Golf Mk4 Help!
    #87
    Thanks Crasher,
    Under (1)VW/AUDI is:-
    01)Engine
    02)Auto Trans
    15)Airbags
    03)ABS Braked
    08)Auto HVAC
    09)Cent.Elect
    Under 01)Engine:-
    1)Read Codes
    2)Erase Codes
    3)ECU Information
    4)Readiness Test
  8. Re: Misfiring Vw Golf Mk4 Help!
    #88
    131 Post(s)
    1979 Post(s)
    Not sure, in VAG protocol 04 is Basic Settings mode and in this you would set the throttle in Display Group 060.
  9. Re: Misfiring Vw Golf Mk4 Help!
    #89
    It looks like my Autel VAG405 is just for reading codes and deleting them.
    My local garage have Snap-On equipment and they say they can reset the Throttle body to the Turbo with it. Does this sound like a good option?
  10. Re: Misfiring Vw Golf Mk4 Help!
    #90
    131 Post(s)
    1979 Post(s)
    Do what? TB to ECU.
  1. Misfiring Mk 4 Golf
    By meatn2veg in forum Golf MK4 - 1999 - 2004
    Last Post: 15-09-2007, 04:20 PM
  2. Mk4 golf probs - juddering, misfiring, lack of power
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 10-06-2007, 09:39 PM
  3. 1990 Golf GTi cabrio misfiring
    By Dave Clark in forum Archive posts
    Last Post: 04-06-2007, 07:53 PM
  4. A4 misfiring please help
    By thegasman2000 in forum Audi A4 - Archive Topics
    Last Post: 03-02-2007, 10:17 PM
  5. misfiring mk3 golf gti 2.0l 16v
    By fazzer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-09-2006, 07:21 PM
