Thread: Misfiring Vw Golf Mk4 Help!
Page 11 of 11 FirstFirst ... 91011
Results 101 to 110 of 110
  1. Re: Misfiring Vw Golf Mk4 Help!
    Nov 2012
    Milford haven, wales
    I have a similar problem. I have a 2000 golf gti 2.0 8v APK which is misfiring at low revs. Have changed leads, plugs, coilpack and fuel filter and it seems to have got worse. Any ideas what could be wrong??
  2. Re: Misfiring Vw Golf Mk4 Help!
    I don't know what is, but I know a man who does and I'm sure he'll be in touch with you soon.
    It sounds like it could be coil packs. Have you replaced them all?
    Best thing to do is have the engine management system analysed and see if any faults come up.
  3. Re: Misfiring Vw Golf Mk4 Help!
    Nov 2012
    Ye coilpacks been changed. Leads and plugs.
  4. Re: Misfiring Vw Golf Mk4 Help!
    131 Post(s)
    1979 Post(s)
    Has a fault code readers plug been waved anywhere in the proximity of the ash tray?
  5. Re: Misfiring Vw Golf Mk4 Help!
    Nov 2012
    So take it to a garage then is what you are saying. Talk about stating the obvious but never mind. Thanks for your help.
    0 0 1
  6. Re: Misfiring Vw Golf Mk4 Help!
    131 Post(s)
    1979 Post(s)
    Listen young man, don't come on here asking for help and then be 5hitty about the FREE advice you receive, it will not be tolerated by myself or anyone else in charge on this forum, when you have contributed 25539 more posts you may be able to start throwing your weight around a little. I get the feeling you would rather throw hundreds of pounds of parts at it in the vain hope that it will be fixed. Do you even realise that in some instances you could fix the fault but because you have refused to do a code read and clear the car will still act up? Owning a fault code reader is not the preserve of a professional establishment, anyone can go and buy one for around the same amount of money your pour down your neck each night!
  7. Re: Misfiring Vw Golf Mk4 Help!
    Nov 2012
    Apologies for being ****** as u say but I wasn't aware that fault code readers were that cheap after going to vw and finding out they charge £59.99 to plug it in. I'm not a fan of these so called specialists in they're field as on more than 1 occasion I have paid extortionate amounts for 1 to tell me that it could be this or that and paying labour costs on top of parts for the problem to still be there. Was hoping that asking for advice on here people who have had a similar sort of fault would point me in the right direction as to where the fault would be. Reason I was sceptical about a fault code reader is that on past cars iv owned the engine management light comes on when there is a fault and mine has not. I have now ordered a fault code reader for less than half of what vw charge and will give that a bash when it comes. Thanks for the advice.
  8. Re: Misfiring Vw Golf Mk4 Help!
    Nov 2012
    Bit more advice if you don't mind crasher. Have read the fault codes and its coming up with p0300 - random/multiple cylinder misfire detected, p0301 - cyl 1 misfire detected and p1582 -idle adaptation at limit. The latter is the first that shows up and believe that this is hopefully just a matter of removing the throttle body and cleaning it?? Was wondering if you would know if the misfiring faults would be showing up as a result of the idle adaptation fault. Iv only just come back home as I work away so am going to give it a go in the next few days.
  9. Re: Misfiring Vw Golf Mk4 Help!
    131 Post(s)
    1979 Post(s)
    On an APK engine I would say that is more than likely a faulty plug, ignition lead or coil pack as these engines are not known for valve burning issues. The idle issue may just require a TB clean but I don't know if you will be able to perform basic settings with the fault code reader you have bought.
  10. Re: Misfiring Vw Golf Mk4 Help!
    Nov 2012
    Well after all that mate I thort I'd av a bash of putting the old plug n lead back on no 1 cyl and turns out the new plug had a crack in the ceramic so she runs like a dream now lol. She was close to being a bonfire. Thanks for your help.
  1. Misfiring Mk 4 Golf
    By meatn2veg in forum Golf MK4 - 1999 - 2004
    Last Post: 15-09-2007, 04:20 PM
  2. Mk4 golf probs - juddering, misfiring, lack of power
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 10-06-2007, 09:39 PM
  3. 1990 Golf GTi cabrio misfiring
    By Dave Clark in forum Archive posts
    Last Post: 04-06-2007, 07:53 PM
  4. A4 misfiring please help
    By thegasman2000 in forum Audi A4 - Archive Topics
    Last Post: 03-02-2007, 10:17 PM
  5. misfiring mk3 golf gti 2.0l 16v
    By fazzer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-09-2006, 07:21 PM
