Thread: Misfiring Vw Golf Mk4 Help!
Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 110
  1. Re: Misfiring Vw Golf Mk4 Help!
    #91
    What ever you said has to be done after taking off the throttle body/ cleaning it and refitting it.
    "the throtle body is 27 on item 24 (inlet manifold) and after cleaning will have to be set up."
  2. Re: Misfiring Vw Golf Mk4 Help!
    #92
    132 Post(s)
    1979 Post(s)
    The throttle body is adapted to the ECU.
  3. Re: Misfiring Vw Golf Mk4 Help!
    #93
    OK that's the one then. Please excuse my incorrect terms, I'm not a technician. What I was trying to establish was:- can the job be done (ie. throttle body adapted to the ECU) successfully using Snap-on equipment and will I need a new gasket after taking off the throttle body?
  4. Re: Misfiring Vw Golf Mk4 Help!
    #94
    132 Post(s)
    1979 Post(s)
    There are a number of Snap On systems but I think they will all do the TB basic setting. Normally the gasket sticks to the TB and does not need replacing but we always stock one just in case it rips.
  5. Re: Misfiring Vw Golf Mk4 Help!
    #95
    I have the gasket now, hopfully the right one, V028 129 748. it has 4 bolt holes in it.
    The two error codes( 17245/17705) haven't reappeared since they were deleted a few weeks ago but I expect them to re-emerge via the engine management light any time now.
    Since its been near freezing in the mornings lately the engine has played up more. It starts up no problem but dies as soon as you try to pull away. Have to give it some revs to overcome this and as soon as I have driven 100yards or so, he engine is fine again.
    Is this related to the error codes does you think?
  6. Re: Misfiring Vw Golf Mk4 Help!
    #96
    132 Post(s)
    1979 Post(s)
    Do another code read now.
  7. Re: Misfiring Vw Golf Mk4 Help!
    #97
    OK not sure if engine should be warm for code reading but this is what I just got with engine cold.
    In addition to the two reoccurring codes, 17545, 17705 I got a couple of new ones,17536 and 16955
  8. Re: Misfiring Vw Golf Mk4 Help!
    #98
    132 Post(s)
    1979 Post(s)
    17545 Bank 1, Learned value of mixture formation (add*) System too rich
    Test fuel pressure regulator and holding pressure
    Test injected quantity and tightness
    Check valve -N80-, Tank Vent Valve
    * add = additive means, that the fault is only effective at idle.
    17705 Compressor - throttle valve connection – Pressure drop
    Check hose connections
    17536 Bank1, Learned value of mixture formation (mult*) System too lean
    Testing injection valves
    Inspect intake system for leaks
    Checking the exhaust system for leaks
    Check tightness of the secondary air system
    Inspect vacuum lines for leaks
    * mul = multiplicative means, that the fault is effective over the full speed and load range.
    16955 Brake light switch -F Implausible signal
    Check brake light switch and brake pedal switch in measured value block, display group 066
    Firstly remove and clean the throttle body and reset in in Basic Settings 060. Then I would fit a new genuine VW dealer supplied exchange Air Mass Meter part number 06A 906 461 LX , replace the split hose under the inlet manifold from the T piece breather valve
    (item arrowed in the picture), part number 06A 103 221 BK for a 2003 Golf 4 GTI with an AUM engine and fit a new brake light switch, 1C0 945 511 A RDW.
  9. Re: Misfiring Vw Golf Mk4 Help!
    #99
    Thanks for the info ... very helpful.
    Not very reliable these VW’s are they…here’s me thinking my problems would be over getting rid of my MK2 with the 2E2 carb. I was looking forward to some trouble free motoring ….WRONG!!!
    I think I mentioned previously that the Exchange Hot Film Air Mass Sensor (part# 0986280217 /£77) and breather Hose (part # 06A-103-221BH /£30) was replaced 4 years ago. Maybe theses weren't genuine VW parts. If they were would they need replacing again?
  10. Re: Misfiring Vw Golf Mk4 Help!
    132 Post(s)
    1979 Post(s)
    Quote Originally Posted by AndySil View Post
    Not very reliable these VW’s are they?
    Its knocking 10 years old and has done what, 100K miles? What do you expect?
    If the hose under the manifold is OK then it is going to need a proper leak test using the VAG pressure testing equipment or a smoke testing machine, there are literally dozens of places the air can be leaking from, if it is that. If the AMM was not a genuine VW part (they have a sicker to say so) then fit a genuine one before going any further.
  1. Misfiring Mk 4 Golf
    By meatn2veg in forum Golf MK4 - 1999 - 2004
    Last Post: 15-09-2007, 04:20 PM
  2. Mk4 golf probs - juddering, misfiring, lack of power
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 10-06-2007, 09:39 PM
  3. 1990 Golf GTi cabrio misfiring
    By Dave Clark in forum Archive posts
    Last Post: 04-06-2007, 07:53 PM
  4. A4 misfiring please help
    By thegasman2000 in forum Audi A4 - Archive Topics
    Last Post: 03-02-2007, 10:17 PM
  5. misfiring mk3 golf gti 2.0l 16v
    By fazzer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-09-2006, 07:21 PM
