Thread: A6 DPF Query
  1. A6 DPF Query
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Afternoon all,
    I have a question about the DPF Regeneration on my 3.0TDi A6 Avant. Now there is nothing wrong with it but I'm curious as to how it works. On my previous car, a 2008 Peugeot 407 there was a fluid called Elyos which was injected into the fuel tank each time the fuel cap was removed, this was used during the DPF regen. Is there a similar thing on my A6 or does it just rely on the Exhaust Gas Temps being high enough to facilitate the DPF regen?
    I'm asking as my car is now at 83k and I'm wondering if its going to need a fluid top up is all.
    Thanks in advance
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  2. Re: A6 DPF Query
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    No fluid required, it uses exhaust / engine temperature to regenerate which is why so many people who insist on buying one and then pottering around town run into problems. If you've not had a problem you're unlikely to get one now. Be aware that the service life for the filter is generally around the 110k mark at which point replacement is required.
  3. Re: A6 DPF Query
    Feb 2016
    53 Post(s)
    Thank you for your reply. I'm averaging about 19k a year and that's mostly motorway miles with a mix of country roads, if we need to do town driving we use the wife's petrol Focus. Did the same with my Pug 407 and that never had an issue with DPF in the 60k I drove it.
    When the DPF filter needs replacing I will pay to have it replaced, it works and I see no reason to try map it out etc.
  1. Can bus query
    By PHASTAZPHUK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-06-2014, 08:52 PM
  2. MAF. Query
    By micheal balbrig in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-10-2013, 09:17 PM
  3. AMI Query
    By Oracle in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-06-2013, 01:07 AM
  4. Question Query - Please help
    By ripcurldude73 in forum The Commercial Range
    Last Post: 29-11-2011, 07:34 PM
  5. New car query
    By Kmacker in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-10-2009, 07:07 PM
