Thread: Allroad alternator upgrade
  1. Allroad alternator upgrade
    Jan 2011
    Falmouth UK
    For work I use the car for powering a charger, the charger draws quite alot of power, 40A as a minimum. When charging I have the car running to keep the battery topped up, but on tickover the alternator is not generating properly and not producing sufficient elactictrickery to keep up with the current draw.
    Is it possible to fit a higher amperage alternator, or some kind of switch to raise tickover rpm when required?
    Car is an Allroad 2.7t
  2. Re: Allroad alternator upgrade
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Could you first get the output checked on your current alternator? It maybe not putting out sufficient current due to worn brushes, regulator issues. An alternator can wack a lot of amperage even at idle, if reguired. Do you know the output on your alt.?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Allroad alternator upgrade
    Nov 2016
    Swindon
    13 Post(s)
    Some places can rewind an alternator for a higher output.
  4. Re: Allroad alternator upgrade
    Jan 2011
    Falmouth UK
    Its probably getting low, i suspect its the original alt and its now over 10 years old. I am also drawing quite high amps, say 40 amps from it.
    I will also look into getting something wound for higher output. It would be good to be able to charge on the road without having to take a generator along
  1. Alternator upgrade question
    By craig-v5-20v in forum Toledo
    Last Post: 05-02-2015, 02:23 AM
  2. allroad 2.5TDi alternator
    By bagpipingandy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-06-2014, 01:23 PM
  3. A6 2.5 tdi allroad air con stopped after new alternator fitted
    By Nev.d.y in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-09-2011, 09:12 AM
  4. Question Re: Allroad Alternator/Battery Problem
    By Tommy-M in forum New Member Introductions
    Last Post: 11-09-2008, 02:35 PM
  5. golfmk3 1.8 driver alternator upgrade
    By spaceman 73 in forum Golf MK3 - 1993 - 1999
    Last Post: 10-06-2008, 05:36 PM
