Thread: VW Phaeton smoking 3.0 0n idle
Results 1 to 10 of 10
  1. VW Phaeton smoking 3.0 0n idle
    Jul 2017
    Falkirk
    I have a 2006 3.0 diesel 225000 miles, when on idle after 5mins starts emitting white smoke really badly, the rest of the times the carruns great plenty power and no smoke.
    I have had it fully serviced oil changed a couple of times aterraclean and a dpf soak which helped a little but still after five minutesidle smoking really badly when I drive the car after that it smokes for 30 secondsthen clears itself.
    Anyone have any idea what this could be or had similar problems.
    Also heard it might be an injector problem.....
    Does anyone have a recommendation for a good garage to diagnose/fix this problem in the Falkirk area ?
  2. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2015
    Staffs
    46 Post(s)
    It will be the injectors.
    Keep an eye on the oil level, just in case the injectors are filling the engine full of diesel.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2017
    Falkirk
    Thanks rowdy will start checking level
  4. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2017
    Falkirk
    Yes level of oil is increasing so i guess it is injectors.... any recommended garages that could fix this ...cheers
  5. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2017
    Falkirk
    Thanks for your help
    It was injectors had them done at a cost of 1500 with my local professional garage.Car is back to normal now ..... well for a wee while anyway lol
  6. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2017
    Falkirk
    Oh used Piezo injectors instead of reconditioned apparently the recon ones don't work so well ???
  7. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2015
    Staffs
    46 Post(s)
    Have you thought no one knew of an garages in your area?
    I did help to pinpoint your problem, so its not all bad.
    Ian
  8. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2017
    Falkirk
    Yea i know was being a bit harsh sorry
    1 1 0
  9. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2015
    Staffs
    46 Post(s)
    I'd be a bit grumpy after an invoice like that too
    Ian
  10. Re: VW Phaeton smoking 3.0 0n idle
    Jul 2017
    Falkirk
    Ha ha yea the thing is, its not the first one lol saying that i didn't think the car could run any smoother but it does
  1. Question Aud A4 3.0 DTi 2006 - Injectors Failing causing smoking at idle
    By duncanhollands in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-04-2016, 08:25 PM
  2. Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    By A11an in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-07-2015, 08:24 PM
  3. Heavy Smoking on Idle - Tandem Up??
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-12-2012, 10:44 AM
  4. A6 3.0 TDi Smoking at Idle - Injector Failure?
    By BDriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-11-2012, 08:15 PM
  5. Idle smoking 3.0
    By t11tmm in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-03-2012, 11:03 PM
