Re: Need help with two "issues" on my Audi A4 B8 –
16-07-2017,09:02 PM
Originally Posted by
WorldUK
Ive got another thing in mind, should i get the rear windows tinted or not? And if do it , get it done by "proffessionals" or buy some ready cut films and do it myself?
Yes, you should, but not very dark and let proffessionals do the job....i tried 20 years ago it was disaster
Regarding brake element of glovebox it is behind passenger fusebox...
Instuction regarding picture above!
Removing and installing cushioning element for glove box lid
Removing
Switch off ignition and remove ignition key.
Remove dash panel end trim (passenger side) → Chapter.
Disengage fuse holder on right of dash panel and slide to one side → Rep. gr.97.
Unplug electrical connector -3-.
Pull out hinge pin -1-.
Release switch -2- in anti-clockwise direction -arrow- and detach
A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
