Thread: Passat exhaust temp sensor
Results 1 to 9 of 9
  1. Passat exhaust temp sensor
    Jul 2017
    Staffs
    I have a 2009 VW Passat 2.0 TDi 130k on the clock. I have recently had the glowplug engine management light come on which has been scanned to a "Sensor 1 for exhaust temp Bank 1 (g235), Circuit malfunction". I believe this is the exhaust temperature sensor located next to the exhaust pressure sensor on the top of the DPF pipe bend.
    I can't find where I can buy this from, when I search it just seems to throw up Lambda sensors. Is this the same thing, has any one got a link to a reasonably priced one? Is it an easy job to do? Any tips? I'm aware that if it snaps thats the DPF written off.
  2. Re: Passat exhaust temp sensor
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    What is your engine code? The part you want is 03L 906 088 but the revision will depend on your engine as there are multiple revisions for this sensor (suffixed by letters A, AT, BS, CC, N etc.). It is the one that they call "before turbo charger" which basically means it screws into the exhaust manifold immediately before the turbocharger exhaust side. They should not snap as the thread is fairly course and the retaining nut around 17mm. You only need to slacken the nut with a crow's foot spanner and this should not put any strain on the sensor itself which rotates inside the nut.
    Mad Mitch
  3. Re: Passat exhaust temp sensor
    Jul 2017
    Staffs
    Thanks the engine code is CBAB. There is also on that looks like it is in the turbo, I assume this is a different sensor?
  4. Re: Passat exhaust temp sensor
    Jan 2012
    10 Post(s)
    88 Post(s)
    G235 is the one in the turbocharger effectively as the manifold and turbo exhaust shell are one unit (the manifold is precast with the turbo exhaust side).
    Mad Mitch
  5. Re: Passat exhaust temp sensor
    Jan 2012
    10 Post(s)
    88 Post(s)
    I would also check the the wiring loom from sensor to connecting block is not too close to or touching any heat shielding as this can melt the wiring. All sensor wiring should be clipped into the guides all the way along and spaced correctly.
    Mad Mitch
  6. Re: Passat exhaust temp sensor
    Jul 2017
    Staffs
    Wiring all good, clipped in no signs off damage
  7. Re: Passat exhaust temp sensor
    Jan 2012
    10 Post(s)
    88 Post(s)
    Part number is 03L906088AP for CBAB.
    Mad Mitch
  8. Re: Passat exhaust temp sensor
    Jul 2017
    Staffs
    Thanks I'll have a look.
  9. Re: Passat exhaust temp sensor
    Mar 2007
    Nr chester
    Could anyone tell me the part number on this sensor for a 2006 Passat B6 170tdi bmr. Got same issue.
  1. Coil lights back on after EGR & exhaust gas temp sensor changed
    By baconandeggs in forum Polo - Derby - Lupo - Fox
    Last Post: 28-11-2016, 07:32 PM
  2. 2009 A3 exhaust temp sensor problem PLEASE HELP
    By Alexis Gibson in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 05-08-2015, 09:50 PM
  3. Audi A4 B8 2.0Tdi Exhaust Gas Temp sensor
    By aaron.ivory.31 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2015, 12:22 AM
  4. Exhaust Gas Temp Sensor
    By Dougster67 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-09-2011, 05:07 PM
  5. URGENT HELP - exhaust/NOX/Gas temp sensor
    By lyndon79 in forum New Member Introductions
    Last Post: 14-12-2009, 03:20 PM
