Thread: Camshaft/Timing Chain Cover seals after engine repair
  1. Camshaft/Timing Chain Cover seals after engine repair
    Jul 2012
    United Kingdom
    Does anyone know whether the camshaft / Timing chain cover seals would have been touched to replace the pistons, rings and rods in an engine on a B8?
  2. Re: Camshaft/Timing Chain Cover seals after engine repair
    134 Post(s)
    2007 Post(s)
    I have sent you a reply to your PM over this
    "Other than to specifically replace the cover lower seal, there is no reason to remove the cover when doing the repairs but some of the access work to remove the head partly goes towards removing the cover so it would be only if it was also having a timing chain system rebuild which you would have to pay extra for and it is a BIG job. There is some crossover work here which could offset some of the costs and if the car has a lot of miles on it, it would be worth thinking about because these chains are becoming an "end of the road" problem for these cars."
    Steve
  1. 2002 AWY Engine Polo Oil Change, Any tips to avoid slipped timing chain?
    By leeanderin in forum Polo - Derby - Lupo - Fox
    Last Post: 17-04-2014, 09:11 PM
  2. Timing chain on 1.4 TSI engine
    By brunel in forum Golf MK6 - 2009 - 2013
    Last Post: 15-10-2010, 05:46 PM
  3. Replacing camshaft oil seals
    By iwaters in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2010, 10:42 PM
  4. A3 Camshaft Timing Chain renewal
    By audi-man in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-06-2009, 09:45 PM
  5. Changing Camshaft Adjuster Seals without draining engine oil
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2008, 09:55 PM
