Thread: Intake manifold removal A4 B7 3.0 TDi - coolant pipe in the way
  1. Intake manifold removal A4 B7 3.0 TDi - coolant pipe in the way
    Jul 2017
    uk
    I've taken all 8 bolts out holding the passenger side intake manifold out but there is a coolant pipe in the way covering one of the holes. I'm trying to carefully bend it out of the way but no joy so far. Any tips on removing the housing so I can replace the swirl flaps? I've searched through the forum but all the photo guides seem to have been hosted on photobucket and will not load as they are blocked from third party hosting.
    Many thanks in advance.
  2. Re: Intake manifold removal A4 B7 3.0 TDi - coolant pipe in the way
    Jan 2009
    Birmingham
    36 Post(s)
    whats your engine code?
  3. Re: Intake manifold removal A4 B7 3.0 TDi - coolant pipe in the way
    Jul 2017
    uk
    Engine code is BKN.
    I managed to get the right hand manifold off in the end by rolling it to the left then wiggling and swearing for about 15 minutes.
    Cleaned the flaps, holes, and shaft. Fitted new arm and wiggled it back in with more swearing.
    Light has gone off and engine hasn't blown up. Good result
    Will attempt the drivers side next week. Wish me luck.
  4. Re: Intake manifold removal A4 B7 3.0 TDi - coolant pipe in the way
    Feb 2009
    West Yorkshire
    10 Post(s)
    Undo this banjo bolt or it will snap the pipe. 10 mm(I think) on a 1/4 " universal joint will do it.just slacken it and move it around so you can take off the intact manifold. Don't take It off completely as it's a bugger to get back on
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  1. Solved Removal of air intake manifold bank 2
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-12-2015, 08:55 AM
  2. egr + intake manifold
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2010, 10:42 PM
  3. Please Help Broken Vac pipe link on intake manifold.
    By bogo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2010, 01:24 PM
  4. Question 2.3 vr5 limo intake manifold removal
    By lemmy01 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-11-2009, 01:48 AM
  5. Intake Manifold ???
    By Bandooli in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2008, 11:50 PM
