Thread: Air conditioning belt question
  1. Air conditioning belt question
    Jan 2017
    Dublin
    I have a quick question
    My aircon has never worked since i got the car
    I still have the belt on the aircon pump,i never use it and it never gets warm enough to use it in ireland
    Is it ok to just run the car without the belt,will it cause any problems
    Basically i just want to take the belt of the aircon pump
  2. Re: Air conditioning belt question
    chester
    17 Post(s)
    If its got its own dedicated belt its ok to remove,if it goes round the alternator etc no unless you can get a smaller serpentine.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  3. Re: Air conditioning belt question
    Jan 2017
    Dublin
    Yes its got its own small belt,goes around crank small tensioner underneath and then around aircon pump and back to crank,the other belt runs the altenator,steering pump,i suspect a squeaky noise is coming from the area and have no need to be running air con pump as i never use it.Cheers
  1. Cam/Timing belt question
    By dcepticon in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-07-2011, 03:16 PM
  2. Air con belt question
    By Fub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-07-2010, 09:01 AM
  3. Question That Cam Belt Question...
    By katycat in forum Bora - 1998 - 2005
    Last Post: 11-03-2010, 05:37 PM
  4. Air conditioning question
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-09-2009, 04:53 PM
  5. Cam Belt Question
    By Pimped-Passat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2007, 09:19 PM
