Thread: 2015 A6 Avant ultra rear parking sensor competently don't work??
Results 1 to 10 of 11
  1. 2015 A6 Avant ultra rear parking sensor competently don't work??
    Nov 2018
    wallsend
    Parking sensor gone faulty after I bought this car about month time. all of the sensor didn't work. Is there any fuse or the control need to replace? Thank you everyone.
  2. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by lee9922 View Post
    There will be a fuse, but it could be a broken wire or a connector has come loose. If you only bought the car a month ago and it was from a dealer then take it back and get them to fix it as it is their legal responsibility
  3. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Jan 2018
    Sussex
    55 Post(s)
    It can be a lot of things.
    Code read with VCDS will tell.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  4. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Nov 2018
    wallsend
    Thank you for reply.
    I bought the car from the vw auction so there wasn't any warranty.
    I had VCDS checked it came six faulty code for every sensor. It saids Open Circuit - Intermittent on every single sensor.
    Anyone know about these please?
  5. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Highly unlikely its all the sensors damaged at once. Possibly the rear bumper has been taken off at some time and the sensor wire not plugged back in.
    Look in the boot and remove the right cubby storage box. There is a small controller about 4" x 4" with 3 plugs on it. make sure they are connected. If they are thne get under the back of the car and check the connectors on the rear sensors
  6. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Jan 2018
    Sussex
    55 Post(s)
    It will be wiring problem or connector.
    Current cars:
  7. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Jul 2016
    Chestfield kent
    81 Post(s)
    Open circuit means that the car is unable to see the sensors. Most likely a wiring fault between the control unit and the sensors, check for damaged wires and/or connectors.
  8. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Nov 2018
    wallsend
    Is anyone know which one is the fuse and ECU of the rear parking sensor?
  9. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi think the large unit at the rear is the control unit Audi, WV, Skoda, Seat part number 4H0919475H try this link to parts web site. Item code appears to be. 4h0919475h the last letter may change but think the rest is the same.
  10. Re: 2015 A6 Avant ultra rear parking sensor competently don't work??
    Nov 2018
    wallsend
    My parts number is 4H0907801H. it seems for the electric parking brake. It saids EPB ECU. Is it same?
  1. 2015 Moonlight Blue A6 Avant 2.0 TDI Ultra Black Edition
    By Spyda in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-06-2015, 10:30 AM
  2. A4 Avant B7 rear parking sensor fault finding
    By cindacone in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-10-2011, 07:34 PM
  3. Rear Parking Sensor retro fitted to A4 Avant by A8 tech
    Last Post: 30-01-2011, 07:25 PM
  4. Replacing rear parking sensor. 2.0 Tdi Avant
    By STAGMAN in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-03-2010, 05:44 PM
  5. Replies: 1
    Last Post: 31-07-2008, 06:33 AM
