Thread: Dodgy O2/Lambda Sensor
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Dodgy O2/Lambda Sensor
    134 Post(s)
    2005 Post(s)
    Avoid taking out and re-installing a Lambda sensor especially if you do not have the correct specification grease such as aluminium or Nickel based extreme temperature types, NOT copper grease! This is because the threads are short and not designed for multi use, strip the thread in your DPF and you will regret trying to save £100 on a sensor when paying for the DPF to be removed, repaired and re-fitted. Also a warning about aftermarket lambda sensors. We will only use Bosch (or NTK where appropriate) and there is nothing wrong with them but we are increasingly having to reject sensors delivered by motor factors as when we get them it is obvious they have been used before and in two cases we have found cleaned up old sensors in the box, only accept sensors that come in a correctly sealed Bosch box with the tamper proof seal intact. In fact second hand parts that have been returned for credit being sent out to us is becoming increasingly common, it has even happened twice from TPS! This isn’t the suppliers fault but that of scumbag garages sending parts back and the collecting and return department staff not being vigilant.
    0 2 0
  2. Re: Dodgy O2/Lambda Sensor
    Apr 2016
    London/UK
    23 Post(s)
    Hi there
    Could you tell me the location of it please?
    I bought a new one and want to replace it on Tuesday but don't know where to start....
    Thanks for your time
  3. Re: Dodgy O2/Lambda Sensor
    134 Post(s)
    2005 Post(s)
    It is in the cat/DPF directly after the manifold flange and before the cat element, this is on the cars right adjacent to the right inner wing, it must be one of the easiest I know to get at.
  4. Re: Dodgy O2/Lambda Sensor
    Jul 2017
    Dollar, Scotland
    Johnro, really sorry but I COMPLETELY forgot to send the sensor. Totally slipped my mind.
    Apologies, mate.
  5. Re: Dodgy O2/Lambda Sensor
    Jan 2018
    Sussex
    55 Post(s)
    If you lift throttle on modern diesel and coast in gear, there is no fuel injected at all.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  6. Re: Dodgy O2/Lambda Sensor
    Jul 2017
    Dollar, Scotland
    Quote Originally Posted by Renars View Post
    I suggest to scan it with VCDS as something else or different may also pop up.
    Yeah that was exactly the symptom with my a6, Renars. Faulty o2 sensor though.
  7. Re: Dodgy O2/Lambda Sensor
    #17
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by lozzyho View Post
    Looks like in other driving conditions car would not recognize faulty sensor yet.
    Was sensor well accessible ?
    Current cars:
  8. Re: Dodgy O2/Lambda Sensor
    #18
    Jul 2017
    Dollar, Scotland
    Yes, absolute doddle to access and replace.
    Open the bonnet and look at the engine cover. Directly to the left of that you'll see the DPF (a metal cylinder). The o2 sensor is in front of the DPF, screwed into it at the point just before it gets fat.
    Very technical description I know!
  1. Solved Replacing a dodgy reversing sensor on my A6 Avant
    By Stevewoodmeuk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-06-2014, 09:39 PM
  2. Question lambda sensor on a mk4 1.6 16v
    By syau in forum Golf MK4 - 1999 - 2004
    Last Post: 01-03-2011, 07:19 PM
  3. Question B1 S1 Lambda sensor
    By quattrocamper in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2010, 11:33 PM
  4. Question lambda sensor
    By monkgti in forum Golf MK5 - 2004 - 2009
    Last Post: 21-01-2010, 07:23 PM
  5. lambda sensor
    By black_mk4_golf in forum Golf MK4 - 1999 - 2004
    Last Post: 29-10-2008, 12:34 AM
