Thread: CRAFTER - Interior lights not working
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. Re: CRAFTER - Interior lights not working
    #21
    Dec 2020
    Berkshire, GB
    As an update for any others with Crafter overhead light issues...
    I replaced the whole unit (with identical part number).
    That sorted it. Now the lights, alarm & rain sensor work.
    Most importantly to stop it happening again I sealed up the aerial using a flexible outdoor sealant (not acetoxy based- you don't want corrosion!) and made a plastic cover for the light unit as a back up to keep water leak or just condensation off the circuit board.
  2. Re: CRAFTER - Interior lights not working
    #22
    May 2022
    Bolton
    Could someone please send me a photo of the common fault on the interior light circuit board please?
  3. Re: CRAFTER - Interior lights not working
    #23
    Oct 2017
    england
  4. Re: CRAFTER - Interior lights not working
    #24
    Aug 2022
    destelbergen
    I have a simular problem at the moment. Interior light are not working when opening my front doors. Measured out the miccroswitches in the door and there both good. I was reading about the lighting module but I can not find it.
    Can somebody please tell me where I can find this module?
  5. Re: CRAFTER - Interior lights not working
    #25
    Oct 2017
    england
    All interior lights and alarm system are controlled by the circuit board on the top side of the interior light unit, in the cab headlining, front and centre.
    Previously.....
    "There are two fixed clips on the left and two spring clips on the right (looking up), nothing front and back.
    Insert a thin blade to depress the clips while pushing the unit to the left. Mine virtually fell out as the headlining has been weakened - I don't think it was the first time the unit had been removed.
    Go careful - if the headlining gets deformed the clips won't hold firmly and the unit will fall on your head when your driving!"
    Good luck.
  6. Re: CRAFTER - Interior lights not working
    #26
    Sep 2022
    Scotland
    I’m having this same lighting issue, I’ve tried look at the pics mentioned but is there a closer view of which ones need bridged
  7. Re: CRAFTER - Interior lights not working
    #27
    Jul 2017
    england
    The pic earlier in this thread was forwarded by 'BrianHale'. I put a red ring around the immediate area where the fault was on mine and posted it up. I'm afraid it's the only pic I have available. The fault(s) may be in a different place on yours anyway - check the circuit continuity near the main input plug socket and work away from there. The fault is probably caused by moisture, so pay attention to any of the board doesn't look 'new' and clean.
  8. Re: CRAFTER - Interior lights not working
    #28
    May 2023
    Sw scotland
    I,m a new member with a crafter 2015.
    I sent my light unit to someone who said that they coul repair it. It turned out that they say they cannot. That,s fine. However they have not returned it, and I stupidly left the sensor attached to the unit , with a brown connector which connects to the lead from the roof.
    I think I've been had.
    The sensor is the real problem. Any ideas.
    Jim
  9. Re: CRAFTER - Interior lights not working
    #29
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Zapped.
  1. Question A3 Door lights and interior lights not working.
    By Markdr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-01-2016, 04:09 PM
  2. Question Vw crafter interior rear lights - fuse
    By Moggsey89 in forum The Commercial Range
    Last Post: 26-01-2014, 10:50 PM
  3. Please Help All interior lights and door lights stopped working in my Sharan 1.9 TDi (Nov 01 New Shape)
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2013, 01:50 AM
  4. Please Help some interior lights not working :(
    By cusford in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-11-2010, 12:53 PM
  5. Interior lights not working
    By Michael Maurice in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-05-2010, 01:44 PM
