Thread: A4 B7 TFSI - replace inlet manifold flapper position sensor without buying whole new inlet manifold?
  1. A4 B7 TFSI - replace inlet manifold flapper position sensor without buying whole new inlet manifold?
    Oct 2014
    United Kingdom
    Hi all,
    I've got the classic intake flapper motor/sensor issue. The dealer's solution is a whole new inlet manifold, and of course re-sealing injectors, and a load of labour hours.
    I've picked up a new flapper motor for good measure, but my error codes are follows:
    012691 - intake manifold runner control
    P3193 - 002 Open stop outside fo valid range
    004248 - Intake Manifold tuning valve position sensor (G336)
    P1098 - 001 - Open or short to Plus
    012600 - Intake Manifold Runner Control
    P3138 - 008 - Regulation Deviation
    It's all looking like the position sensor, rather than the motor, which I gather is a separate unit, and part of the inlet manifold. I've not installed the new motor yet, as I don't want a dodgy position sensor try to make the motor move beyond its capabilities.
    Is it possible to get hold of the position sensor by itself and replace, or am I going to need to get the whole new inlet manifold and take a pounding from the local VAG dealership?
    It's the older 200HP TFSI engine. 8ED model.
    Thanks in advance.
  2. Re: A4 B7 TFSI - replace inlet manifold flapper position sensor without buying whole new inlet manifold?
    Oct 2014
    United Kingdom
    In case someone else gets this, I ended up swapping out the motor, clering error codes, and running the initial setup, and this has fixed the issue. No more hesitation/misfire feel at around 2000RPM, and especially when cold.
    Looks like better fuel economy when driving modestly, too.
  1. inlet manifold flap position sensor (bank1) P2015 00
    By climbachia in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-03-2018, 02:54 PM
  2. Replies: 3
    Last Post: 18-10-2016, 02:32 PM
  3. Had to replace Inlet Manifold on 2010 CC at 66K miles
    By Colin.Gillan in forum Passat CC
    Last Post: 05-08-2013, 08:00 PM
  4. Replies: 3
    Last Post: 20-04-2013, 12:19 PM
  5. Oil in the Inlet Manifold and EGR
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-08-2011, 04:01 PM
