Thread: idles erratically then stall
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Exclamation idles erratically then stall
    Jun 2007
    hello again i have a problem with my passat 1.8 t i had it chip couple of months ago then suddenly i expereince the erratic idle then the engine stall & it takes time to restart the engine agin its annoiying especially when the car stall on the traffic lights. so what i did i put the older chip back then the car starts. i dont know if the tuned chip is the problem or other components coz i used the tuned chip couple of months & it was ok but lately its just happen the idles playing up & down then stall.pls if anyone could give me a solution for this i really appreciate so much as of now i'll observe the old factory chip for the meantime.thanks
  2. Re: idles erratically then stall
    Oct 2007
    Belgrade,Serbia
    It is the throtle body that is the problem.Take it off cleane it and do the basic seting with the vag com and it willbe OK. The most problems that Ive seen on this forum are similar to yours and it suprisses me that most of people dont konow about it when this is common problem.
  3. Re: idles erratically then stall
    Kent, UK
    If this only happens when the engine is warmer... then it could be the same problem I had, which was coolant temprature sensor. Worth getting it scanned or scanning yourself with VAG-COM.
  4. Re: idles erratically then stall
    Jun 2007
    thanks for your reply mate but this happen suprisingly not always like this before but only now really terrible expereince i change the coolant temperature sensor new one day after its really playing the idle then stall & i cant start the car anymore but when i put the factory chip back thats the time the car starts without hesitation the idle is find.is there a possibility that the car ecu or other components can damage the tuned chip?coz i think its like the engine misfires i dont know. im confused coz if i use the old factory chip the car start when i use the tuned chip it wont start. anyway im going to cleaned the throttle body again coz thats what the tuned chip company said i hope.
  5. Re: idles erratically then stall
    Sep 2007
    Had a similar issue with my BMW, stalling randomly - it was a cam position sensor.
    Of course I don't know if the 1.8T has one so I could be barking up the wrong tree...
    -Steve
    MY00 BMW E39 M5 - Silverstone\Black-Grey (garage queen)
    MY02 Passat TDI-130 Sport Estate - Grey\Leather-Alcantera (daily driver)
    17mpg & 400bhp or 50mpg & 130bhp... now which one shall I take...
  6. Re: idles erratically then stall
    Jun 2007
    Yes What Im Confusing About That When I Put The Factory Chip Back The Car Start Without Hesitations When I Put The Tuned Chip It Wont Start. Im Using The Tuned Chip For 2 Months And Its Find Only Now The Idle Is Playing Then Stall But Not Everyday When I Used It. The Problem Just Puff Out Suprisingly.
  7. Re: idles erratically then stall
    133 Post(s)
    1989 Post(s)
    Have you got equipment to read fault codes? You could try cleaning and resetting the throttle body.
  8. Re: idles erratically then stall
    Jun 2007
    yes i have but i cant do it today coz its raining maybe tomorrow then i'll see if it works.
  9. Re: idles erratically then stall
    ChillOut Guest
    Quote Originally Posted by ANGELO33 View Post
    Sounds like you need a refund from the chip tuner, or at least more help from them for free. I don't think VW will want to help much !!!
  10. Re: idles erratically then stall
    Jun 2007
    YAH THEY SAID ITS THE THROTTLE FLAP ANYWAY I GOT IT DIAGNOSE TODAY AND THIS WHAT I GOT
    16885 (P0501) Vehicle Speed Sensor Range/Performance
    INTERMITTENT
    670-- ------- Throttle Position Sensor -G127
    Incorrect Signal INTERMITTENT
    17967 (P1559) Idle speed controller
    INTERMITTENT
    SO IS THIS ONE OF THE POSSIBILITY THAT THE IDLES PLAYING & STALL?I CLEARED IT BY THE WAY & IM GOING TO CHECK AGAIN IF STILL APPEAR.
  1. 1999 2.0l Bora idles OK but no power
    By barry1066 in forum Bora - 1998 - 2005
    Last Post: 19-10-2007, 06:09 PM
  2. My Golf mk3 1.4 revs erratically when i drive it
    By tommo81 in forum Golf MK3 - 1993 - 1999
    Last Post: 08-10-2007, 08:21 PM
  3. 2003 A6 with occasional stall
    By paul b in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-09-2007, 10:50 PM
  4. Car idles but wont drive
    By boycey19690 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-01-2007, 12:08 PM
