Thread: Component protection intermittent on airbags
  1. Component protection intermittent on airbags
    May 2008
    26 Post(s)
    this showed up on a scan at the weekend - no date attached to the fault. From reading up it sees. Component protection means a trip to the dealers to remove the fault, but as it says "intermittent" is it a real problem? No airbag error light is displayed, but when I run a VCDS scan "ESP fault" shows on the dashboard display then goes away.
    Can this be caused by a dying battery, as I've had to get a charger onto it a couple of times due to SOC low warnings.
    Address 15: Airbags Labels: 4F0-910-655-8R.clb
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 43 AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0SZPAD
    Coding: 0013363
    Shop #: WSC 02325 758 00200
    VCID: 295E26E6806262099E-807C
    Subsystem 1 - Serial number: 6332CSME1623182E+
    Subsystem 2 - Serial number: 6342CSME1623615C+
    Subsystem 3 - Serial number: 6352QSME325916014
    Subsystem 4 - Serial number: 6362QSME3479414DN
    Subsystem 5 - Serial number: 63734SME334D2135Z
    Subsystem 6 - Serial number: 63834SME3013150FU
    1 Fault Found:
    02095 - Component Protection Active
    000 - - - Intermittent
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  2. Re: Component protection intermittent on airbags
    46 Post(s)
    I wouldn't worry, random bugs can make their way into a controller.
    And yes, the ESP fault when scanning is normal.
  3. Re: Component protection intermittent on airbags
    May 2008
    26 Post(s)
    Thanks Chris, so I can assume my airbags are working because there's no fault light and it's safe to ignore the error on vcds? Good to hear the ESP fault while scanning is normal. Had me a bit worried!
  4. Re: Component protection intermittent on airbags
    46 Post(s)
    Correct!
  1. component protection
    By paulz in forum Golf MK6 - 2009 - 2013
    Last Post: 23-12-2016, 12:54 PM
  2. Component Protection
    By hufodorp in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2016, 11:56 PM
  3. Component Protection
    By audi_guy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-04-2014, 02:31 PM
  4. Component Protection??
    By sbaffi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-01-2014, 10:44 AM
  5. Component Protection
    By Zenerdiode in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-01-2014, 10:34 PM
