Thread: Getting gassed out. Turbo to DPF connection leaking.
  1. Getting gassed out. Turbo to DPF connection leaking.
    Mar 2017
    Redditch, Worcestershire
    I'm hoping someone might be able to help me. I have a 57-plate GT TDi 170 DPF. Recently I have noticed that when I stop at traffic lights there is a slight smell of exhaust gasses in the cabin. This was recently looked at at a VW specialist.
    They found that where the turbo connects to the DPF there is a clamp/union which looks like there is a leak of gasses as the connection is sooted up. They have quoted me £400 to replaced the connection as apparently you have to drop the sub frame to do this. Does this sound right? Or can it be changed without having to removed anything and nibble arms. I have looked and I can't access from the top as the bolt appears to be on the bottom of the clamp that is facing down.
  2. Re: Getting gassed out. Turbo to DPF connection leaking.
    134 Post(s)
    2002 Post(s)
    The DPF comes out without dropping the subframe and even if you do drop the centre section it is quick and easy. IF the centre section is removed the bolts MUST be replaced.
  3. Re: Getting gassed out. Turbo to DPF connection leaking.
    Dec 2014
    Bedford
    42 Post(s)
    Done loads. New clamp and a metal ring gasket. No need to drop the subframe. Just remove the clamp and ring. Undo a 13mm bolt on the left just behind the head under exhaust gas pressure sensor. Then undo 2 13mm nuts on back of block that hold the lower part of the dpf. Remove dpf to front silencer sleeve. Fit new ring gasket and clamp nip it up gently keeping it completely flush with turbo flange. Then gently nip up the nuts and bolts previously mentioned and fit a new sleeve. Then tighten up from dpf/ turbo working backwards to sleeve. £400 is a hefty bill. Parts genuine are max £30. Easy peasy on a ramp. Think we charged the last customer about £120 all in.
  4. Re: Getting gassed out. Turbo to DPF connection leaking.
    Mike McKinstry Guest
    Hi I have a leak between dpf and turbo and can see black deposits under v clamp so went to dealer for clamp which I’ve got but they’ve told me it’s common for dpf to warp and that changing clamp and small metal ring seal will not cure the leak/fumes to cabin??Is this the case?If so is there any alternative to a new dpf?Also what is the sleeve mentioned in the above post couldn’t see this on vagcat so haven’t got yet is this essential to change or could this cause spot deposit near clamp?car is 2.0 cr tdi 59 plate golf.
    Many thanks as always
  5. Re: Getting gassed out. Turbo to DPF connection leaking.
    134 Post(s)
    2002 Post(s)
    We have never had a V band flange distort, a new gasket and band clip always seals.
  6. Re: Getting gassed out. Turbo to DPF connection leaking.
    Well that would be good news -will have a go Thursday thinking sleeve must just be joint in pipe half way along floor?
  7. Re: Getting gassed out. Turbo to DPF connection leaking.
    134 Post(s)
    2002 Post(s)
    No it is directly on the turbo, before the DPF.
  1. Please Help Audi a3 air con help re gassed but hissing
    By bluecolin in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-06-2012, 09:44 AM
  2. turbo leaking
    By a4paddy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-08-2011, 10:46 AM
  3. Turbo leaking oil
    By Dannyg81 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-04-2010, 06:57 PM
  4. leaking Turbo
    By ravanoli in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-09-2009, 07:20 PM
  5. Please Help Oil leaking from turbo
    By Ian Lane in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-08-2008, 11:01 PM
