Thread: Car intermittently not starting, cranks fully (S4 B6)
  1. Car intermittently not starting, cranks fully (S4 B6)
    May 2016
    East london
    I've run into a problem since yesterday intermittently whereby my car will crank and crank but not start. Randomly it will start, and randomly it won't. It's happened about 3/10 starts since yesterday, no new codes are showing (except G28 speed sensor), I was told by a friend it may be electrical and looking online it looks like maybe a relay but I'm hoping it's not a fuel or pressure issue.
    I'm trying to sell my car and have someone viewing this weekend so don't want to sink too much into the car but I don't want to sell it to someone if it has a big problem. Any advice is appreciated - I'm aware of the airbag MIL and rear left light along with the alarm codes:
    Code:
    Friday,23,June,2017,21:17:55:11979
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170320 DS267.7
    www.Ross-Tech.com
    VIN: WAUZZZ8E64A071458   License Plate:
    Mileage: 157660km-97965mi   Repair Order:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
              67 69 75 76 77
    VIN: WAUZZZ8E64A071458   Mileage: 157660km-97965miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8E0 910 560 B    HW: 8E0 907 560
       Component: 4.2L V8/5V      G   0020
       Coding: 0011771
       Shop #: WSC 33278 133 00032
       VCID: 2443AFDBE4F53461AD-515A
    2 Faults Found:
    17979 - Left Engine Mount Solenoid Valve (N144)
                P1571 - 001 - Short to Plus
    16706 - Engine Speed Sensor (G28)
                P0322 - 004 - No Signal - Intermittent
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 09L-927-760.lbl
       Part No SW: 8E0 910 156     HW: 09L 927 156
       Component: AG6 09L 4.2L5V RdW  0020
       Revision: 00000001    Serial number:        0001719
       Coding: 0001001
       Shop #: WSC 63351 000 00000
       VCID: 63C1ECC7A17B735994-515A
    No fault code found.
    Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
       Part No: 8E0 614 517 Q
       Component: ABS/ESP allrad      3033
       Coding: 04597
       Shop #: WSC 06435
       VCID: 366765931269B6F103-513C
    Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
       Part No: 8E0 820 043 AA
       Component:   A4 Klimaautomat   1219
       Coding: 00000
       Shop #: WSC 63351
       VCID: 60CBE3CBE06D684189-515A
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  RDW 0517
       Coding: 00011
       Shop #: WSC 63351
       VCID: 3565629F0F6FBDE90A-4B32
    2 Faults Found:
    00984 - Left Tail Light (M4)
                57-00 - Electric Circuit Failure
    01312 - Powertrain Data Bus
                79-00 - Please Check Fault Codes
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 B
       Component: Airbag 8.4EP        3002
       Coding: 0010602
       VCID: 366765934269B6F103-515A
    1 Fault Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
                001 - Upper Limit Exceeded - MIL ON
    Address 16: Steering wheel        Labels: 8E0-953-549.lbl
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 01141
       Shop #: WSC 63351
       VCID: 3E777DB33A597EB1DB-4B32
    2 Faults Found:
    00576 - Terminal 15
                57-10 - Electric Circuit Failure - Intermittent
    00883 - Ignition Switch (D) Terminal S
    Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
       Part No: 8E0 920 980 L
       Component: KOMBI+WEGFAHRS. RB4 D36
       Coding: 01400
       Shop #: WSC 00001
       VCID: 3565629F0F6FBDE90A-515A
       Subsystem 1 - Part No: 71458
       Component: AUZ6Z0C0081035
       71458     AUZ6Z0C0081035
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0604
       Coding: 00001
       Shop #: WSC 00000
       VCID: 6BD184E719AB3B192C-513C
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
       Part No: 8E0 959 433 BC
       Component: Komfortgerát T3B    1311
       Coding: 06891
       Shop #: WSC 63351
       VCID: 73E19C87419BE3D9E4-4B18
       Subsystem 1 - Part No: 8E2959802B
       Component: Tőrsteuer.FS BRM 0003
       Subsystem 2 - Part No: 8E2959801B
       Component: Tőrsteuer.BF BRM 0003
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0003
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0003
    3 Faults Found:
    01134 - Alarm Horn (H12)
                49-00 - No Communications
    01366 - Opened Due to Crash Signal
                35-00 -  -
    01561 - Rear left door
                61-10 - Won't De-Safe - Intermittent
    Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
       Part No: 4Z7 907 357
       Component: dynamische LWR       D09
       Coding: 00060
       Shop #: WSC 63351
       VCID: 0403CF5B1435D461CD-4B4A
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 8E0 035 186 J
       Component: concert II  GRO    0008
       Coding: 01202
       Shop #: WSC 63351
       VCID: 2E574DF3EA398E314B-4B18
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283 A
       Component: Parkingsyst. A4 RDW D09
       Coding: 01104
       Shop #: WSC 06435
       VCID: 43810C4751BB1359B4-5178
    2 Faults Found:
    00625 - Vehicle Speed Signal
                27-00 - Implausible Signal
    01550 - Signal for Reverse Gear
                27-10 - Implausible Signal - Intermittent
    End-------------------------(Elapsed Time: 05:28)--------------------------
  2. Re: Car intermittently not starting, cranks fully (S4 B6)
    Dec 2007
    I don't know if it will help, but I had this problem on my B7 avant a few years ago, as you say it would crank fine but not start, I noticed that when it wouldn't start the glow plug light didnt come on, turning ignition on and off would fix after a number of attempts, but it gradually got worse it turned out to be the body control module not communicating with the engine module therefore not switching the imobilizer off.
    luckily I had an aftermarket warranty that covered the cost.
  3. Re: Car intermittently not starting, cranks fully (S4 B6)
    Feb 2009
    West Yorkshire
    10 Post(s)
    If the ecu cant detect the speed of the engine, it doesn't know its turning / cranking. Surely it wont start. Not a professional or mechanic, just my thoughts.
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  4. Re: Car intermittently not starting, cranks fully (S4 B6)
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If you've got vcds there you can check the cranking speed I think it needs to be 280rpm minimum to start ( you'd best check that, it rings a bell with me though). does the rev counter jump up when cranking? if not the G28 may be the fault, if the rev counter works maybe your battery or starter is a bit tired, that ignition switch fault code looks suspicious as well.
  5. Re: Car intermittently not starting, cranks fully (S4 B6)
    scotland
    39 Post(s)
    Quote Originally Posted by gurpreet94 View Post
    Code:
    www.Ross-Tech.com
              67 69 75 76 77
       Coding: 0011771
    2 Faults Found:
       Coding: 0001001
       Coding: 04597
       Shop #: WSC 06435
       Coding: 00000
       Shop #: WSC 63351
       Coding: 00011
       Shop #: WSC 63351
    2 Faults Found:
       Coding: 0010602
    1 Fault Found:
       Coding: 01141
       Shop #: WSC 63351
    2 Faults Found:
    00576 - Terminal 15
       Coding: 01400
       Shop #: WSC 00001
       Coding: 00001
       Shop #: WSC 00000
       Coding: 06891
       Shop #: WSC 63351
    3 Faults Found:
                35-00 -  -
       Coding: 00060
       Shop #: WSC 63351
       Coding: 01202
       Shop #: WSC 63351
       Coding: 01104
       Shop #: WSC 06435
    2 Faults Found:
    It's the crank angle sensor, engine speed sensor, easy enough to change. Don't delay fixing it as it will eventually totally fail and leave you stranded
    Luckily it has logged the fault code, it doesn't always trigger it.
  1. Car not starting - intermittently.
    By felixoscar in forum Golf MK4 - 1999 - 2004
    Last Post: 08-01-2015, 09:02 PM
  2. Trouble starting - cranks but does not start
    By VWGEEK in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2014, 10:49 PM
  3. 1.6 fsi not starting intermittently
    By ttemme in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-10-2009, 01:25 PM
  4. Please Help 97 a4 1.8t aeb cuts out after starting intermittently
    By nick_a4t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-08-2009, 01:36 AM
  5. Polo intermittently not starting
    By Gee Bee in forum Polo - Derby - Lupo - Fox
    Last Post: 24-01-2007, 09:44 PM
