Thread: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
Results 1 to 10 of 17
  1. Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Aug 2015
    Bexleyheath
    Hi Guys,
    i have an 2012 A6 C7 estate and have been receiving these error messages for the past month. Strange thing is that sometimes it can go for a week without any message, and then sometimes every time I start the car I get these messages.
    I have already had some relays, ABS sensor on a wheel and also battery replaced. None of these helped. Have any of you encountered this behaviour please?
    Thank you for your help guys.
  2. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Pembrokeshire
    22 Post(s)
    you need to know what fault codes you have.
  3. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Aug 2015
    Bexleyheath
    I do have a vcds scan, will attach it later tonight.
  4. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Mar 2014
    Edinburgh
    235 Post(s)
    Have you had pads or discs changed recently?
    it could be something simple and a multi plug wasn't connected properly or the wiring loom could be buggered. Especially the rears as there are a lot of people out there who think they know how to work the electronic brake when replacing pads/discs and end up breaking the rear calipers.
    its all connected, tpms and esp relies on the abs sensor and the abs sensor uses a toothed ring on the hub/disc.
    2015 272 saloon Fl, lighting pack, 19" 10 spoke alloys, electric boot, memory seat with folding mirrors, tech pack, silver leather interior and privacy glass.
  5. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Aug 2015
    Bexleyheath
    Thank you for your advice. I was receiving the errors even before i had the front brake pads changed. They were wore down, so had to replace them. Not the rear ones though.
    The wheel sensor that was replaced based on error message readings was the drivers front.
  6. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Aug 2015
    Bexleyheath
    Could it be something related to fact that i had winter tyres&rims swapped for summer ones? Last year I had no trouble with this swap, but is it possible they broke something when they were swapping them round?
    Havind said that, the garage would have probably spotted any problems as they were replacing brake pads.
  7. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by A6S View Post
    I had that on CC, did a scan and it was rear right abs sensor. 10 miles later left one died.
  8. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Aug 2015
    Bexleyheath
    Am I assuming right that the scan should tell you which sensor is the one in question? They did the scan and based on results, replaced the ABS sensor. This however has not cured the problem in my case
  9. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Mar 2014
    Edinburgh
    235 Post(s)
    Could it be the toothed ring that the sensor relies on rather than the sensor itself?
    The abs sensor detect speed from this toothed ring by measuring the pulses. If the ring is buggered then it will throw up a warning fault.
  10. Re: Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    Jun 2015
    Ireland
    69 Post(s)
    VCDS will tell you exactly which sensor is causing an issue. It could be dirt on the toothed ring or just another sensor died. They all have same mileage. That happend to me. Instead of replacing both rear at the same time I had to do it week after week.
  1. Noisy rear brake calliper (electronic parking brake)
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-08-2016, 06:41 PM
  2. Please Help Two questions - hl brake light & side light errors
    By rosso rocket in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-07-2013, 05:27 PM
  3. ABS, Parking Brake, Squeeking brakes and brake lights!
    By medvwb6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2011, 05:35 PM
  4. 2004 Golf Mk4 1.4 Match - Misfire & Brake Switch Errors.
    By mlilburn in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2009, 08:45 AM
  5. Tmps ???
    By johnvw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-10-2009, 07:16 PM
