Thread: just in the process of buying an Audi A5 sportback 2012 MY2013
  1. just in the process of buying an Audi A5 sportback 2012 MY2013
    Jun 2017
    anything I need to watch out for?
    ive put my VCDS cable on it and there is an error on the steering assist. but it was about 2 months ago and flagged as intermittent priority 6. I haven't got the log as I'm at work. will post the code later.
    it seems to drive well enough and I wonder if the code is because the battery has run flat at some point?
    also I checked the vin number and it seems it has had its ecu updated to fix the emissions scandal. what negative effects will this produce? as I did notice some almost as if it was going to stall episodes when stopping at junctions, you could feel the rpm dropping.
  2. Re: just in the process of buying an Audi A5 sportback 2012 MY2013
    Jun 2017
    Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
    Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
    Component: RCEPS H37 0507
    Revision: 00001000 Serial number: 0002697590
    Coding: 100000000001
    Shop #: WSC 00976 210 89512
    ASAM Dataset: EV_RCEPSAU48X 008014
    ROD: EV_RCEPSAU48X_008.rod
    VCID: 34677AF59FEAFCE13D-8060
    1 Fault Found:
    2305 - Function Restriction due to Start Voltage Interruption
    U1410 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 21
    Mileage: 97426 km
    Date: 2017.03.30
    Time: 15:42:52
    valid
  3. Re: just in the process of buying an Audi A5 sportback 2012 MY2013
    Jun 2017
    also is there an issue with them catching fire? seen a few post about it.
  4. Re: just in the process of buying an Audi A5 sportback 2012 MY2013
    Maidstone
    Hi
    I have just purchased one a couple of months ago! Catching fire I have not heard of this!?!!?
    You have not mentioned if manual or auto - Apparently you should ensure the auto gearbox oil has been changed every 38k miles as stated by manual or problems could arise with box issues.
    Things to look out for (auto box), gear change should be smooth with no delay or noises.
    Hope this helps in some way.... I am lovin ours now she has been tweaked!!
    Audi S5 3.0TFSI 354 Quattro Sportback 8sp Tiptronic 2018
  1. Please Help Fitting RNS-E to 2012 A3 Sportback Sport
    By CalvinStoke in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-04-2015, 11:32 AM
  2. Winter wheels for 2012- A3 Sportback
    By Diamond Dawg in forum Wheels and Tyres
    Last Post: 25-03-2014, 04:28 PM
  3. Question What to look out for when buying 2nd hand Audi A3 Sportback
    By a3_tdi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-12-2010, 07:32 PM
  4. Please Help Buying an Audi A3 Sportback Quattro, which one?
    By JOAKES24 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-01-2010, 08:45 AM
  5. Question Buying new A3 Sportback options comments please
    By chiefwiggumpi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-05-2009, 09:30 PM
