Thread: One touch window not lifting
  1. One touch window not lifting
    May 2015
    United Kingdom
    OK, on just the drivers door the one touch will drop the window OK, but not lift it. I have tried the drop and hold the button, lift and hold the button routine and no difference. I have also given the window channel a squirt of silicon spray.
    I do have VCDS if that helps, but can't see anything obvious - but then I don't really know what I am looking for.
    Thanks,
    Paul.
  2. Re: One touch window not lifting
    Jan 2016
    Winchester Hants
    29 Post(s)
    If you can lift it perhaps try the reset.
    VW Volkswagen One Touch auto window resetting - YouTube
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 68K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  3. Re: One touch window not lifting
    May 2015
    United Kingdom
    Thanks for the reply - that's the drop & hold, lift & hold I mentioned, unless there's some nuance to it I missed.
  4. Re: One touch window not lifting
    May 2015
    United Kingdom
    RESOLVED! - faulty switch.
    I noticed the switches all are two stage - nudge the window or all the way. Nothing happened on the first stop with the driver's door, and second position was the nudge.
    Popped the switch off and had a look - the switch itself was physically damaged - possibly yanked a bit hard at some point - it I held the back of the switch down and lifted the front it worked as expected.
    Replacement arrived today, fitted, and all working as expected.
    The switch panel is a but snug, isn't it!
  5. Re: One touch window not lifting
    Jan 2016
    Winchester Hants
    29 Post(s)
    Dooohhhhh, my front passenger window is suffering the same and return to default does not sort it.
    It's the drivers side passenger switch that is at fault so a complete new module is required. VW quoted £50 so that's not too bad.
  6. Re: One touch window not lifting
    May 2015
    United Kingdom
    Mine was around half that new on eBay
  1. One touch window
    By aks1989 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2015, 11:44 AM
  2. Question CCM Unit, Auto Dimming Rear View Mirror, One Touch Passenger Window
    By Woz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2013, 10:38 PM
  3. Golf lifting front door window rubbers
    By cdgthreesalmons in forum Golf MK6 - 2009 - 2013
    Last Post: 13-02-2012, 10:07 PM
  4. une touch up driver window, key, vacuum pump, phone connect
    By AdilSD in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-05-2011, 09:38 AM
  5. A4 One touch window problem
    By Stub in forum Audi A4 - Archive Topics
    Last Post: 08-04-2007, 06:44 PM
