Thread: Audi A6 Avant Lower Door Mould Rust/Bubbling
Results 1 to 10 of 11
  1. Audi A6 Avant Lower Door Mould Rust/Bubbling
    Jan 2017
    Dublin
    Probably been mentioned or said before
    Noticed slight rust/bubbling on leading edge of bottom of both front doors
    Removed all lower door mouldings of the 4 doors on my car
    Found lots of muck/Crud
    Cleaned to find that on all 4 doors the moulding has been rubbing against paint,Caused paint to flake exposing the metal,moisture and water has caused rust bubbling
    Clearly a design flaw by audi,Mouldings must have slight movement
    Might have caught it early enough to treat
    Just warning people to check their own cars
    1.9tdi Avant Awx 2002 332,000 KMs
  2. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Apr 2015
    Damascus, Syria
    From the pics, I'd say that its a case of insufficient paint thickness on the very edge of the door, and you can see it all along the door edge. Normally, you don't get rust bubbles from a loose moulding, even if there is a lot of crud underneath it, unless the original paint work was poor even before the moulding was fitted...Best to clean it, and put a coat of primer on the exposed paintwork under the mouldings. touch it up with top coat, and replace the mouldings. For the edges, touch up with primer and top coat, and that should stop the rust from spreading any further..Plus there is a coat of hard wearing heavy duty material sprayed on the lower sills, you can check this by rubbing your hand along the sills and feel the roughness, it looks like orange peel finish. In some vehicles, this coating can be found along the lower part of the doors too.
    Hope that this helps,
    All the Best, Jim.
  3. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Pembrokeshire
    22 Post(s)
    15 year old car, design flaw ??? lol, seriously.
    0 2 0
  4. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Jan 2017
    Dublin
    Id agree with you there jim,insufficient paint thickness and before i purchased the car it had no mud flaps which would stop road debris taking the edge of door
    I am going to do that when the weather picks up a bit
    Thanks for the feedback
  5. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Jan 2017
    Dublin
    Exact same on all 4 doors zollaf
    4 drains on bottom all full of muck/Crud
    Moulding moving and rubbing
    Perfect condtions for rust with paint flaking exposing bare metal
    Should have used an altenative method of holding mouldings to door
    Check your own A6 C5 if you have one
  6. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Pembrokeshire
    22 Post(s)
    its a 15 year old car. if the drains are full of crud then clean them out, thats not the fault of the car , is it ? but the car has lasted 15 years, you dont see many other cars that are 15 years olf cos most have been scrapped due to falling apart. if the car was 3 years old then yes, you could call it a design fault, but its not, its 15.
  7. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Jan 2017
    Dublin
    I did clean them out,was like cleaning out an elephants zoo enclosure
    I am sure cars that were 3 year old suffered with this problem especially on roads that were heavily salted,You would want to remove mouldings every 6 months to clean them
    Its a great car i am not complaining about it
    Mechanical side will way outlast the body
    Was only letting people know of this problem if they intend on keeping an A6 C5
    0 2 0
  8. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Nov 2011
    Duns Scotland
    11 Post(s)
    My 2002 Allroad has just had its front two doors replaced. I have two rear breaker replacents in my garage for respray and fitting in August when I get back to UK.
    Now I have to say when I First got my Allroad from new, I did notice all the crud getting trapped in the bottom of the door moulds - between rubber seal and the door mould. Now this area is not near the actual metal door - in fact when I replaced the two front doors, I could not see ANY drain holes! The mould fits into holes in the bottom of the door and mould is then 'locked in place' by moving it towards the door hinge.
    In my case, I think it is simply condensation over the 15 years I have had the car - down in France over the summer sitting under a wisteria pergola where temp can soar, can rain lots and can be humid.
    The annoying thing, it is only removal of two screws to remove the interior door trim and you can then see the full interior bottom of the door. If I had known this it would have been easy to prevent this RUST FROM THE INSIDE happening.
    AS YOU SAID, GO CHECK YOUR DOORS NOW!
  9. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Jan 2017
    Dublin
    I am going to treat mine as soon as i can,I will take pictures of the 4 mouldings when they are of the car
    Mine are fixed the same way,2 Screws at either end to hold in place,however there is still slight movement,Perhaps a long bead of silicone on the top and bottom would stop the movement
    They were a pig to remove because there was so much crud in the drain channel at bottom of the door,took a a few heavy hits with the side of my hand to budge them
    Will check mine from the inside also to see if the rust has gone to far
    Cheers for the tip
  10. Re: Audi A6 Avant Lower Door Mould Rust/Bubbling
    Jan 2017
    Dublin
    For anyone intrested in this thread,link to show the door blade rust
    Lower door doorblade rusting - AudiWorld Forums
  1. Lower door rubber trim- Drivers side A6 S-line Avant
    By Bernieburger75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-01-2014, 05:03 PM
  2. rust to lower door panels
    By jay mac in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-03-2011, 11:04 PM
  3. Please Help 04 8P Rust Lower Door
    By keicar in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-04-2010, 02:14 PM
  4. help wanted audi quattro avant 99 tdi 180 roof rust bubbling
    By rooos in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-05-2009, 11:14 AM
  5. Should my 2 year old a4 have rust bubbling on the bootlid??
    By glynburrtwo in forum Audi A4 - Archive Topics
    Last Post: 27-09-2007, 10:01 PM
