Thread: G65 Thrust Sensor - 2006 2.0TDi 170
Results 1 to 8 of 8
  1. G65 Thrust Sensor - 2006 2.0TDi 170
    Hi all,
    My air con stopped working so I had it regassed but it still didn't work. After reading on here about the G65 high pressure / thrust sensor, I thought for £25 it would be worth a try.
    So I followed the guides for replacement on here, bumper off and headlight out. Removed the plug from the sensor. Next up was put a 17mm spanner on the sensor to unscrew it. This is where I think I had a problem.
    The sensor came off, but not via any threaded screws - it popped/blew off followed by the woosh of my air con refrigerant escaping. There are no threads on the air con pipe the sensor connects to so I can't see anyway this can be right. There is no way to fit a new one or even the existing one.
    Can anyone advise? What I thought would be a simple job now appears to have turned into a headache. Any help/advice appreciated.
  2. Re: G65 Thrust Sensor - 2006 2.0TDi 170
    134 Post(s)
    2018 Post(s)
    Nasty, the sensor thread has sheared off in the AC pipe, new pipe. That can also cause nightmares as they don't like coming of the condenser or the valve block.
  3. Re: G65 Thrust Sensor - 2006 2.0TDi 170
    Does anyone have a photo of what the end of the A/C pipe should look like with the sensor removed?
    Any ideas on the best place to get a replacement pipe?
  4. Re: G65 Thrust Sensor - 2006 2.0TDi 170
    Jul 2015
    Staffs
    46 Post(s)
    It would look a bit like a big tyre valve.
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: G65 Thrust Sensor - 2006 2.0TDi 170
    Thanks for the photo. My valve that should be on the A/C pipe is inside the pressure switch.
    New pipe it is then. Does anyone know of any guides for replacement or tips on the process to avoid breaking anything further?
  6. Re: G65 Thrust Sensor - 2006 2.0TDi 170
    Dec 2014
    Bedford
    42 Post(s)
    Did you check for a live feed at the plug 1st? I done one the other day and it was just a fuse blown.
  7. Re: G65 Thrust Sensor - 2006 2.0TDi 170
    Yes, checked the fuses - both fine.
    I assume no issues with the plug connection, as when it's removed the ECON light is on. When it was plugged in - no ECON light on.
  8. Re: G65 Thrust Sensor - 2006 2.0TDi 170
    134 Post(s)
    2018 Post(s)
    Actually it means a new condenser, Audi number 8E0 260 403 T £408.13 genine.
    Cheap and cheerful http://www.eurocarparts.com/search/222440521
    Quality Denso Condenser
  1. Audi a3 2006 2.0tdi wont start after replacing genuine crank sensor
    By rwh1000 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-07-2015, 05:07 PM
  2. Replace High-Pressure Sensor/Thrust sensor G65)
    By jrabkid in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2013, 04:15 PM
  3. Question G65 thrust sensor
    By pauleire in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-07-2012, 09:42 AM
  4. Question 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Chat - Anything with wheels
    Last Post: 22-07-2011, 09:44 PM
  5. Please Help 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-07-2011, 07:58 PM
