Thread: A4 b6 cab handbrake adjustment
  1. A4 b6 cab handbrake adjustment
    Mar 2015
    Kent
    Anyone know how to tighten the handbrake on a A4 b6 1.8t cabriolet ?
  2. Re: A4 b6 cab handbrake adjustment
    Jan 2009
    Birmingham
    36 Post(s)
    This any help?
    Adjusting handbrake
    Note
    t The rear brakes are self-adjusting, so the handbrake does not require [COLOR=#1B8EDE !important]adjustment[/COLOR] in normal [COLOR=#1B8EDE !important]operation[/COLOR]. Re-adjustment is only necessary after renewing handbrake cables, brake calipers, brake pads or brake discs.
    t The footbrake system must be bled and must be functioning properly.
    t Handbrake lever, handbrake cables and brackets must be fully installed.
    [COLOR=#1B8EDE !important]Adjust[/COLOR] lever position at brake calipers using feeler gauges to ensure that A = 1.5 mm.
    Depress brake pedal firmly at least three times.
    For [COLOR=#1B8EDE !important]illustration[/COLOR] purposes, the [COLOR=#1B8EDE !important]diagram[/COLOR] shows the handbrake lever after it has been removed from the vehicle.
    Press release button, item -2-. (Both spring-loaded hooks must catch eyelets on handbrake cable.)
    Let go of the release button.
    Firmly apply the handbrake lever at least 3 times.
    Place handbrake lever in rest position.
    Press release button. (Both spring-loaded hooks must catch eyelets on handbrake cable).
    [COLOR=#1B8EDE !important]Remove[/COLOR] feeler gauge from brake calipers.
    Check lever position at brake calipers.
    Distance A between lever and stop must be between 0 and 1.5 mm.
  1. Handbrake Adjustment
    By Llew86 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-06-2010, 02:12 PM
  2. Please Help Handbrake adjustment.
    By burnleywhite in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2010, 04:09 PM
  3. How To Handbrake adjustment
    By Andante in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-07-2009, 12:25 AM
  4. Handbrake Adjustment
    By grahamcoutts in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-10-2008, 07:51 AM
