Thread: Audi A6 C6 2008 Starting , AC and central Lock problem
Results 1 to 10 of 25
  1. Audi A6 C6 2008 Starting , AC and central Lock problem
    Jun 2017
    Morroco
    6 Post(s)
    Hello Mates ,
    I am new in this Forum and I would like to thank all moderator to be accepted here .
    Please excuse me as I am new in this forum for my problem description and also I am new as an Audi owner
    I m a new owner of an an A6 C6 2.4 PETROL , BDW engine code Multitronic 7g GEARBOX , 2008
    I have some issue with my car as following :
    1-/ Key can not unlock the car doors : I have to open manually from the driver door :
    VCDS diag
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 227
    2-/ Starter problem : car wont start only after several attempts and I hear a noise from the starter side : it s coming from the starter head which I think it need replacement , so it s a mechanical problem
    VCDS diag
    [05] - Access/Start Authorization
    01176- Key 004 - No Signal/Communication - Intermittent
    Fault Priority: 2
    Fault Frequency: 225
    Reset counter: 227
    00446 - Function Limitation due to Under-Voltage: Lower Limit Exceeded
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 207
    and in the Engine Blocks I think I have related issue
    [01] -Engine Electronics
    006450 Data bus powertrain , implausible message from immobilizer
    P1932 - 008 - intermittent
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 21
    3-/ Battery error :
    3-/ Address 61: Battery Regul. Labels
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 9
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    02276 - Quiescent Current Stage 5
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 4
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    5-/ AC : not working
    despite the blower blowing and I read meas blocks found pressure 7.6 Bar when engine idling , blower working , but compressor not coupling !
    VCDS DIAG : NO ERROR .
    Please help .
    with kind regards
    Adel75
  2. Re: Audi A6 C6 2008 Starting , AC and central Lock problem
    131 Post(s)
    1978 Post(s)
    The battery is flat and/or not charging which is a common issue on these when the signal wire from the alternator to the battery controller fails.
  3. Re: Audi A6 C6 2008 Starting , AC and central Lock problem
    Jun 2017
    Morroco
    6 Post(s)
    Hello Mate ,
    Thank u for the reply , I guessed that , Battery changed with a new Varta one 100AH , nothing changed still all the 3 issue sitted up : key locking not working , starter also difficult , AC not working
    any help pls , which part is the cause , how can I track all these issues
    regards
    Adel75
  4. Re: Audi A6 C6 2008 Starting , AC and central Lock problem
    131 Post(s)
    1978 Post(s)
    What codes are coming back after a full clear, drive and re-read?
  5. Re: Audi A6 C6 2008 Starting , AC and central Lock problem
    Jun 2017
    Morroco
    6 Post(s)
    Hi sorry for my late reply I was away from the car
    work done Boss : I have clear the faults drove the car and here my issue let s solve it one by one
    1-/ difficult starting :
    the sound coming from the starter I will attack this week , I will put new starter because I take a look on the starter and it seems to be out ! sound grezzzzz and only starting after several time even after putting the new battery
    Diag
    Adresse 01: Moteur (BDW) Labels: 06E-910-552-BDW.clb
    No. pièce Log: 4F2 910 552 Mat: 4F0 907 552 F
    Pièce: 2.4l V6 MPI 0010
    Révision: --H20--- No. de série:
    Codage: 0105001002070160
    No. Atelier: WSC 02325 785 00200
    VCID: 62D7CAE3A7BDAA2021-8036
    1 Fault Found:
    009523 - Ignition Switch; Run/Start Position Circuit
    P2533 - 006 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 2
    Fault Frequency: 1
    Address 05: Acc/Start Auth
    2 Fault Found:
    00166 - Access/Start Authorization Switch (E415)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 2
    Fault Frequency: 1
    et
    Fault Priority: 2
    Reset counter: 227
    wich is going and coming after erasing
    what s responsible of that ?
    I still also have my remote not able to open the door , I still open the door mechanically !!!
    please help
    with kind regards
    Adel
  6. Re: Audi A6 C6 2008 Starting , AC and central Lock problem
    131 Post(s)
    1978 Post(s)
    At the moment you need a new ignition switch, a fairly common problem and easy to deal with.
  7. Re: Audi A6 C6 2008 Starting , AC and central Lock problem
    Jun 2017
    Morroco
    6 Post(s)
    Hi Everyone :
    just to update , I left the headlight issue for the future when I will have enough time to fix them
    let s resume :
    1-/ opening car door using remote : issue solved by changing Ignition switch .
    2-/ starter problem : new starter installed .
    3-/AC not working : new compressor installed : AC work perfect .
    5-/ full car maintenance was done : engine oil , fuel filter , spark plug , brake pads , AC filter , radiator cooling , only CVT multitronic oil change not done will be tackled separately later .
    car issue now :
    1-/ ABS problem : ESP light is on , ABS light off !!!
    diag :
    [01] - Engine Electronics
    18061/P1653/005715 - Please check DTC Memory of ABS Controller
    [03] - Brake Electronics
    00526 - Brake Light Switch (F): 008 Implausible Signal
    I think I need to change the brake switch .
    I have used one : can someone help how to test if it s good or not ? Thanks , dealer does not have stock , I will try to find OEM new one ! my concern is that is the brake switch is faulty : why the ABS light is not on !? also if the Brake switch is faulty : whay I have the ESP , it should be more related to the ABS , no ?
    yesterday took the car for a long drive : around 500 KM , issue noticed : engine keep reviving on 4000tr/min , car not shifting ! even took my feet from the gaz : RPM stay blocked on the 4000 tr/min and engine noise coming and car keep in the same gear ! diag : Engine , Gearbox : no error only the related to ABS found in engine section
    I am suspecting the throttle body need some cleaning ! it feel like there is no synchronization between the engine and the gearbox
    I tried a kick down : I am in the 5 th gear and kick down when it come to 5000 tr/min and it change to 6 th gear and despite my feet still down on the GAZ pedal , the rpm go s to 4000 tr/min and I have to push again to get a new kick down for 6th to 7 th gear ! no continuous kick down !
    something wrong : or is it the car power train management not behaving normal : reduced power due to ESP light on !
    ur help will be very appreciated
    regards
    Adel
  8. Re: Audi A6 C6 2008 Starting , AC and central Lock problem
    Jul 2013
    76 Post(s)
    Just replace the brake light switch as it does more than put the brake lights on this should solve the ABS issue.
    Dan
    2009/2010 2.0 TDIe SE
  1. Please Help Drivers Door Lock/Central Locking Problem
    By Bigdogcasa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2011, 03:38 PM
  2. Please Help Passenger door lock/central locking problem
    By kahunajb in forum Golf MK4 - 1999 - 2004
    Last Post: 28-10-2010, 08:32 PM
  3. Starting problem and broken door lock
    By SAZ2696 in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2008, 01:58 PM
  4. Central lock problem Passat 1.8T 2000
    By tjompen1968 in forum Archive posts
    Last Post: 19-09-2006, 09:37 PM
  5. Central lock problem
    By tjompen1968 in forum Passat - Archive Topics
    Last Post: 19-09-2006, 09:36 PM
