Thread: Golf TDI MK4 hot starting problem
Results 1 to 10 of 21
  1. Golf TDI MK4 hot starting problem
    derbyshire
    Hi Guys
    I could do with your help to help my golf mk4 GT TDI 110 1998.When she has warmed up even after a 2 or 3 mile run and stopped ,then when you try and restart it it takes 10 or 15 seconds to start.I have had the vag com software on and there are no faults and the pump timing is spot on I have changed the 109 relay the temp sender was changed 6 months since,that was changed to try and cure the over heat warning light coming on when the car has being parked up over night and the air temp is below 5c but the new sensor did't cure that but back to the issue ,I have put new o rings in the fuel filter T ,It has had new fuel return pipe from injectors to the pump.There is some random air bubbles in the fuel pipe but that is there when is starts from cold and there is no problem then.The battery is in a1 condition only 18 months old.So after all that I am at a loss to what to do next so it is over to you guys to try and shed some light on what I could do next.
    Scotty
  2. Re: Golf TDI MK4 hot starting problem
    135 Post(s)
    2036 Post(s)
    I have had this due to a faulty starter motor. The rather odd diagnostic procedure is to recode the ECU for an automatic box and see if the problem goes away. If it does, replace the starter.
  3. Re: Golf TDI MK4 hot starting problem
    derbyshire
    Thanks I will plug the old girl onto the laptop and try it thanks.It does sound odd but anything is worth a try.
    I will keep you posted
    Scotty
  4. Re: Golf TDI MK4 hot starting problem
    check earth cable from battery to gearbox make sure it is clean & secure it was a known fault on 20v turbos with hot start problems
  5. Re: Golf TDI MK4 hot starting problem
    Oct 2007
    Nottingham
    Have you checked out the usual suspect, the sticking anti-shudder valve? It's the 'throttle' on the manifold, when you turn the engin off observe it operate. When stopped, it shoudl then spring back to the 'open' position. Make sure you work it and check it's 'open' before starting the car, see if this fixes. If so a clean and service of your manifold likley to fix it. It's also possible to remove the egr and the anti shudder thouch each has consequences and more involved than just unbolting the bits - read past posts.
  6. Re: Golf TDI MK4 hot starting problem
    derbyshire
    I have now checked and cleaned the earth strap so I will see how it goes 2morrow and the anti shudder valve you can hear when you turn the engine off every time, but I will check it when it has a run 2morrow I have also replaced the duel temp sender again because when you disconnect the plug when it won't start it starts straight away so it is a total mind boggler.
    Thanks scotty
  1. Starting Problem - Golf V5
    By SiJP in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2007, 01:43 PM
  2. Golf III TDi, Starting Problem
    By Joe911 in forum Golf MK3 - 1993 - 1999
    Last Post: 08-10-2007, 08:30 PM
  3. Cold Starting Problem Golf 1.9d (95)
    By ak07oct in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-02-2007, 03:45 PM
  4. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
  5. Golf 1.8GL Starting problem
    By rulleyman in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-02-2006, 07:09 PM
