Thread: Golf TDI MK4 hot starting problem
Results 11 to 20 of 21
  1. Re: Golf TDI MK4 hot starting problem
    Jul 2007
    derbyshire
    It must be that the starter is drawing to much power and that it might not be turning the engine over fasting enough.That is my only sugestion about the prob I have found some info on a ecu repair company and that says about the hot start problem http://www.bba-reman.com/content.asp...ips_volkswagon.
    Scotty
  2. Re: Golf TDI MK4 hot starting problem
    Mar 2007
    northumberland
    It is something to do with the starter motor speed, when the car is warm it will not inject fuel until the engine reaches a certain rpm, I think its 250rpm when cold it injects straight away, this is what i have read elsewhere switching the ecu to auto will allow it to inject straight away even if its hot.
  3. Re: Golf TDI MK4 hot starting problem
    135 Post(s)
    2037 Post(s)
    As I said Greg, I don't know why this works.
  4. Smile Re: Golf TDI MK4 hot starting problem
    Jul 2007
    derbyshire
    Quick update I altered the ecu to think it is a auto and it starts fisrst time everytime and I have being using it in the auto setting and there does'nt seem to any driverablity issues it just put a fault code in the ecu saying there is no TCU input signal.Thanks for the info lads I will be stripping the starter us to see if there is any probs that can be fixed if not then a new starter it is.
    Scotty15
  5. Re: Golf TDI MK4 hot starting problem
    Sep 2007
    Bath, England
    Got the same problem with my car and starting when warm. How do you change it from manual to auto? Is there any problems when changing over to auto?
    Alex
  6. Re: Golf TDI MK4 hot starting problem
    135 Post(s)
    2037 Post(s)
    You need a fully working copy of VAG-COM to recode the ECU. I can't recommend driving the car like this, I am sure it must do long term harm, it is purely as a diagnostic aid and if people end up using it as a bodge, I will regret revealing it.
  7. Re: Golf TDI MK4 hot starting problem
    #17
    Jul 2007
    derbyshire
    Quick update I have removed the starter and stripped it down and cleaned it up got all the cr*p out of it and it is back on the car now and it starts just like it used to first time everytime.
    Thanks for the help and advice
    Scotty15
  8. Re: Golf TDI MK4 hot starting problem
    #18
    135 Post(s)
    2037 Post(s)
    Was it full of black dust?
  9. Re: Golf TDI MK4 hot starting problem
    #19
    Jul 2007
    derbyshire
    yes it was but it is'nt now.
    Scotty
  10. Re: Golf TDI MK4 hot starting problem
    #20
    135 Post(s)
    2037 Post(s)
    That is an indication of dual mass flywheel failure. A lot of remanufactures now refuse warranty on recon starters that fail if they are full of this dust.
  1. Starting Problem - Golf V5
    By SiJP in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2007, 01:43 PM
  2. Golf III TDi, Starting Problem
    By Joe911 in forum Golf MK3 - 1993 - 1999
    Last Post: 08-10-2007, 08:30 PM
  3. Cold Starting Problem Golf 1.9d (95)
    By ak07oct in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-02-2007, 03:45 PM
  4. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
  5. Golf 1.8GL Starting problem
    By rulleyman in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-02-2006, 07:09 PM
