Thread: Central locking problem drivers door A4 - I've read all the posts!
Results 1 to 10 of 14
  1. Central locking problem drivers door A4 - I've read all the posts!
    May 2017
    Norwich
    Newbie looking for help with newly purchased A4 B8 2008. When I lock the doors with the remote fob (1 click only) the drivers door doesn't always unlock. When I lock the doors (2 clicks) it does seem to unlock. It always unlocks on the key however.
    The cars been standing a while as it was a bereavement car so hoping the can of wd40 I squirted in the lock this morning will sort it. But if not what's the general consensus? Actuator?
  2. Re: Central locking problem drivers door A4 - I've read all the posts!
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by Bear77 View Post
    If you read all posts then you should know, that answer is yes, most common issue is lock/actuator
    Repairing Audi A4 B8 8K door not unlocking with remote fob
    I had same issue with my drivers door, a bit lock oil spray and play with fob, did a magic, two years now without problem!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Central locking problem drivers door A4 - I've read all the posts!
    May 2017
    Norwich
    Quote Originally Posted by Gunnark100 View Post
    Fingers crossed that's what it is and no expense. Otherwise I'll be back to tell you about it 😱
  4. Re: Central locking problem drivers door A4 - I've read all the posts!
    133 Post(s)
    1987 Post(s)
    If you had read all the posts you would know that THE most important step is a code read of the incontinence system to see what is stored.
  5. Re: Central locking problem drivers door A4 - I've read all the posts!
    Oct 2012
    Estonia
    64 Post(s)
    +1
    9 out of 10, if it unlocks with second push:
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 38
    Reset counter: 234
    Mileage: 116404 km
    Time Indication: 0
    Date: 2016.03.16
    Time: 06:25:02
  6. Re: Central locking problem drivers door A4 - I've read all the posts!
    133 Post(s)
    1987 Post(s)
    IF that code is stored in the relevant door controller.
  7. Re: Central locking problem drivers door A4 - I've read all the posts!
    May 2017
    Norwich
    I don't really want to paid Audi £100 to read a fault code! Now I notice the rear passenger door won't open from outside under any circumstances. Is it just one actuator in the drivers door which controls them all? Or is there a control unit in each door?��
  8. Re: Central locking problem drivers door A4 - I've read all the posts!
    May 2017
    Norwich
    Ok I've a plan! Following further reading I think the door actuators in the drivers door and rear nearside door are shot. So tomorrow I'm going to try the following:
    1. Resync the keyfob - (if anyone has a link to how to do this for a 2008 B8 that would be great and thank you)
    2. Put a new battery in the keyfob (expect this won't change anything)
    3. Check to see if I can hear the nearside rear door lock or offside rear door lock working (offside is fine by the way)
    4. Disconnect the battery - leave for 15 mins and then reconnect
    5. Remove the rear nearside door trim and read the part code from the actuator before ordering one from fleabay or GSF car parts.
    Any other ideas I would love to hear - this is really p***ing me off now! And not sure if this is significant but there's no beep when I lock the car - I read on some posts that there should be. Only had the car for 48 hours and yes, I did read up on common A4 B8 problems but you can't find everything! I mean who checks to see if all of the door locks work on a second hand car? Really?
    I'm working on the assumption that actuator/solenoid/door lock mechanism are all used interchangeably as on eBay they all look the same!!!
    Oh and is this any good? 17.1 2017 NEW RELEASE FOR VCDS VAG COM HEX CAN DIAGNOSTIC TOOL FITS AUDI VW FULL | eBay
  9. Re: Central locking problem drivers door A4 - I've read all the posts!
    133 Post(s)
    1987 Post(s)
    There is no beep because the central inconvenience system is seeing a fault so it is not going into safe mode, you need a code read.
  10. Re: Central locking problem drivers door A4 - I've read all the posts!
    May 2017
    Norwich
    Ok so I know I need a code read - can someone suggest a good reader or alternatively a good lead plus software for a laptop link?
    I've now stripped down the door and the obvious replacement is the actuator module as it's an easy swap. But my local guy says he doesn't sell many but sells lots of the latch mechanism. However, I can't get to this as the door latch is bolted in with some kind of screw I've never seen before (almost like a ten threaded T40 torx screw) - so I've taken some pictures.
    Firstly the cable all seems intact and is attached to the door handle and it does move when the door handle moves - just doesn't unlock anything.
    So I'm really stuck - I don't know whether to order an actuator as the linkage all looks good - alternatively can someone tell me what the hell I undo and remove the latch with?
    I've drawn around the cable from the door handle to the cable in red so you can see it clearly.
  1. Question central locking only opens drivers door??
    By domaldinio in forum Golf MK4 - 1999 - 2004
    Last Post: 29-08-2017, 06:51 PM
  2. Replies: 5
    Last Post: 15-11-2014, 08:05 PM
  3. golf mk4 1.4S, drivers side door central locking problem
    By eurobenjy in forum Golf MK4 - 1999 - 2004
    Last Post: 23-12-2012, 08:51 PM
  4. Please Help Drivers Door Lock/Central Locking Problem
    By Bigdogcasa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2011, 03:38 PM
  5. Central Locking Not Locking Drivers Door
    By davieb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-11-2008, 10:37 PM
