Thread: Removing front bumper for G395 sensor - question
  1. Removing front bumper for G395 sensor - question
    May 2008
    26 Post(s)
    Hi
    im trying to take the front bumper forward a few inches on the right hand side (as you face the car from front) so I can get at the G395 air con pressure sensor to swap it for new. I was under the impression you can undo the fasteners all except the 10mm nut on the left side, then bring the bumper forwards far enough.
    I've taken out the three bolts along the top and one 10mm nut on the RHS but can't get the bumper further than pictured and don't want to force it without first asking advice. Does the headlamp washer Union need to be re over / repositioned to get it further? Is there something else I've missed?
    i can probably get a spanner on the old sensor as the bumper currently sits, but cannot get anywhere near the electrical connector to unplug that, as you can probably see in the third pic.
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  2. Re: Removing front bumper for G395 sensor - question
    Jul 2013
    76 Post(s)
    Behind the inner wheel arch there is a plastic cover remove this to access the 10mm nut.
    You need a long extension for this job.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Removing front bumper for G395 sensor - question
    May 2008
    26 Post(s)
    Thanks, done that already but still can't get the bumper off more than about 10mm so my question was why? Are there more fasteners, is it the headlamp washer Union, or is it just plastic clips which need a good shove to get disconnected?
  4. Re: Removing front bumper for G395 sensor - question
    Jul 2013
    76 Post(s)
    Have you taken the under tray fasteners off?
    Dan
  5. Re: Removing front bumper for G395 sensor - question
    May 2008
    26 Post(s)
    Thanks, had taken the undertray fasteners off but hadn't spotted the three t25 torx screws which are in that same vicinity and visible once you prise the side of the bumper outwards a little. Dealt with that and the headlamp washer Union (gave the garage floor its annual bath time) and then I could get to the G395 easily. Surprisingly easy job to change it overall.
  6. Re: Removing front bumper for G395 sensor - question
    Feb 2017
    Stockport, UK
    Hi!, I have been searching for a G395 sensor where did you get one from and what price?
  7. Re: Removing front bumper for G395 sensor - question
    May 2008
    26 Post(s)
    I bought mine on eBay, direct from Poland. £31 delivered and it appears to be genuine VW product
    NEW A/C PRESSURE SENSOR AIR CONDITIONING AUDI A3 A4 A5 A6 A7 A8 Q5 R8 4H0959126A | eBay
  1. Air con G395 sensor no vaultage help please
    By rapter in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2017, 01:11 PM
  2. Question Removing front bumper - easy job????
    By Big G star in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-01-2011, 10:10 PM
  3. HELP! Removing front bumper - how?
    By Two_Stripes in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-10-2009, 01:42 AM
  4. Removing Front Bumper
    By Stuart_B in forum Golf MK4 - 1999 - 2004
    Last Post: 06-08-2009, 10:51 PM
  5. Please Help Can the front lower skirt/lip be removed from bumper w/out removing it all ???
    By shaft-50 in forum Golf MK5 - 2004 - 2009
    Last Post: 24-03-2009, 11:03 PM
