Thread: Do I need a single or double sided serpentine belt?
  1. Do I need a single or double sided serpentine belt?
    May 2017
    Hi folks,
    So as the title suggests, I'm in some doubt as to which belt to get. I've a 04 Bora TDi 100BHP, and the belt decided to up and disintegrate somewhere out in the country last night, so I've no belt to compare it to. The Haynes manual is no use, as it just gives me diagrams for both with and without aircon. All I can find out is that I need the one that turns the aircon compressor as well, but I don't know if I need single or double sided ones.
    Micksgarage.com is no use, and indeed they are recommending two different length belts for use with aircon, which is... unseemly. Most are offering the 1195mm version, so I'm just presuming that's the one I need, but I'm not positive by a long shot.
    Any advice you can offer would be greatly appreciated,
    Cheers,
    WP
  2. Re: Do I need a single or double sided serpentine belt?
    Jan 2008
    Hi! I recently had a similar quandary - I ordered a new tensioner and the pulley was smooth instead of ribbed. On closer inspection the belt had worn the old one slightly so it resembled a grooved pulley!
    I have an '02 with the same engine (I think) and it uses a double sided belt.
    Ps. It's usually best to post / search in the Golf IV section as nobody seems to read the Bora section.
  3. Re: Do I need a single or double sided serpentine belt?
    2007 Post(s)
    I hope he has it sorted by now or his battery will be flat...
  4. Re: Do I need a single or double sided serpentine belt?
    May 2017
    Sorted indeed cheers, I went for a double sided belt, which was bang on. The flat tensioner was a bit of a red herring.
  1. Squeaky Aux / serpentine belt caused by belt or pully? Video included.
    By mikeote in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-07-2016, 09:13 PM
  2. How To single din to double
    By abby1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-03-2016, 09:57 PM
  3. single din to double din
    By keith price147 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-05-2013, 05:44 PM
  4. vibrating noise & belt slip on full lock- serpentine belt tensioner?
    By VtecJunkie in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-12-2009, 04:39 PM
  5. Please Help Single din to double din
    By sompop in forum In Car Entertainment
    Last Post: 07-04-2009, 12:18 PM
