Thread: CAN Gateway location
  1. CAN Gateway location
    Apr 2015
    Flintshire
    Where is the CAN Gateway located on an a3 tdi 8p?
  2. Re: CAN Gateway location
    46 Post(s)
    behind the glovebox, why do you need access to it?
  3. Re: CAN Gateway location
    Apr 2015
    Flintshire
    I have fault codes for: can gateway, alarm horn, interior monitors, radio ( my radio is aftermarket), and relay 449 under the dash drivers side is always hot ( can only touch it for about 5secs) and battery is draining. The only thing I can find that doesn't work if I pull the relay out is the interior light.
    So I'm wondering if there all linked to can gateway issue?
  1. RCD 310 , can bus gateway
    By elliebumpkins in forum In Car Entertainment
    Last Post: 30-06-2014, 06:53 PM
  2. Question Can Gateway Location
    By daclyn in forum Golf MK5 - 2004 - 2009
    Last Post: 29-08-2013, 08:44 AM
  3. Question Can Gateway Location
    By daclyn in forum Golf Plus
    Last Post: 03-09-2010, 08:03 AM
  4. GATEWAY...step by step guide on how to re-code the gateway
    By maddogphysics in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-06-2010, 01:15 PM
  5. Where is the CAN BUS gateway?
    Last Post: 17-06-2010, 06:33 AM
