Thread: Touran AC fault
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Touran AC fault
    Dec 2014
    Bedford
    42 Post(s)
    17 = Compressor off (no signal or implausible signal from High Pressure Sensor -G65-)
    Yes no power from control unit if there is a shut off code
    So g65 first. Then make sure you have enough gas in the system. Erase faults and it should be all good.
  2. Re: Touran AC fault
    Cornwall
    System re-gassed. Loss was 0.250Kg (capacity 0.575Kg) and no leaks apparent. Fault still evident.
    I've ordered a new pressure sensor, fingers crossed it's that simple.
  3. Re: Touran AC fault
    Cornwall
    Pressure switch replaced, no change to fault.
    As I suspected, the fault lies with the lack of power to the switch. Does anyone have an accurate wiring diagram for a 2004 RHD Touran TDi or know where the power comes from for the G65 switch?
    Many thanks
  4. Re: Touran AC fault
    Dec 2014
    Bedford
    42 Post(s)
    What's the code now in block one field one. Give me a reg i will see where pin 1 gets a feed from.
  5. Re: Touran AC fault
    Cornwall
    Still code 17, still blank pressure reading.
    WJ54 YHR
    Thanks for your help.
  6. Re: Touran AC fault
    Dec 2014
    Bedford
    42 Post(s)
    Ok climatic manual ac Up to April 2005 shows pin1 is earth... 2 is sensor voltage to pin 5 on ac control unit... 3 is live to pin 7 on relay fuse plate 1 to fuse f3 5amp. But also check fuse f52 f35 f15 f31 f7 f24 also f6 (80 or 100 amp). Fuse f3 gets its power from terminal 1 on fuse plate back to fuse f40 20amp and f8 10 amp .
  7. Re: Touran AC fault
    #17
    Dec 2014
    Bedford
    42 Post(s)
    Earth leads back to earth point either in osf or nsf a pillar
  8. Re: Touran AC fault
    #18
    Dec 2014
    Bedford
    42 Post(s)
    Fuse plate 1 is inside car by driver
  9. Re: Touran AC fault
    #19
    Cornwall
    Quite often problems have the simplest of resolutions.....
    Checked fuse plate 1 and lo and behold, no fuse in position 3!
    Quite why not, I have no idea. I hadn't noticed the missing fuse, but did check all those that were there. Closer inspection found the 5A fuse in the wrong position.
    It's possible that the fuse was moved because of a fault, but I'm not refitting the old sensor to find out.
    It all appears to be working now, so good news. Thank you for your help.
  10. Re: Touran AC fault
    #20
    Dec 2014
    Bedford
    42 Post(s)
    No worries. Glad its fixed. The switches are common as muck so I wouldn't be too upset about replacement.
  1. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  2. Question Touran ecu fault
    By christopher1970 in forum Touran - Sharan - Caravelle
    Last Post: 09-04-2013, 04:47 AM
  3. touran 1.9 tdi starting fault
    By tractor fixer in forum Touran - Sharan - Caravelle
    Last Post: 27-02-2010, 05:52 PM
  4. vw touran 1.9 tdi start up fault
    By tractor fixer in forum New Member Introductions
    Last Post: 20-02-2010, 01:57 AM
  5. touran fault codes ?
    By itsshreck in forum New Member Introductions
    Last Post: 14-12-2009, 03:13 PM
