Thread: 2002 b6 avant locking issues
  1. 2002 b6 avant locking issues
    Mar 2006
    county durham (north east uk)
    For some reason my 2002 a4 avant has stopped locking with key in drivers door lock, unlock with key is fine &
    Locks & unlocks with fob ok,
    Any ideas?
  2. Re: 2002 b6 avant locking issues
    Jul 2016
    Anglesey
    If my memory serves me right, there is a flexible cable from the back of the rotating key cylinder which engages into the door lock mechanism. It's possible it's slipped out of position as it's only a push fit. Unfortunately, to get at it you will need to take the door card off and also the window and winder mechanism. Some good guides on YouTube!
  3. Re: 2002 b6 avant locking issues
    Mar 2006
    I thought the same myself,
    But removed the lock mechanism complete as i thought maybe a lock mechanism problem,
    & plugged into the harness & used a flat screwdriver to turn the (key piece) & still the same lock only locks the drivers door only (mechanically) unlock unlocks all doors with central locking,
    So im still scratching my head at the moment,
    I have checked coding with vcds & all is good
  4. Re: 2002 b6 avant locking issues
    Jul 2016
    Anglesey
    Sorry, I misunderstood. I thought you meant it wasn't locking the driver's door. I've got three suggestions:
    1. Corroded terminals in the door terminal plug/socket (that was my problem)
    2. Broken wire in the door harness - usually where it bends as the door is opened.
    3. Faulty microswitch in the actuator unit. This unit can be opened up and the switch cleaned or replaced. The switch detects when you turn the key clockwise, I think there is another switch for counter-clockwise.
    I'd look for them in the order above - easiest first!
  5. Re: 2002 b6 avant locking issues
    Mar 2006
    Thanks, much appreciated,
    Will get stuck into it again this next week, (weather permitting)
  6. Re: 2002 b6 avant locking issues
    Jul 2016
    Anglesey
    Good luck. I might have an old drivers door lock in my scrap pile if I haven't thrown it. I'll check when I get home as there might be some useful bits in it or I can take photos
  1. Wiper issues> you should know this. A4 2002.
    By monzaz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-01-2017, 01:04 PM
  2. Please Help 2000 Avant central locking issues.
    By Dan 80 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-10-2016, 10:09 AM
  3. MPG issues on 2002 A4 1.9TDi Quattro
    By Muiry8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-09-2012, 08:10 PM
  4. Please Help Passat 2002 central locking issues
    By rosco in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-01-2012, 10:52 PM
  5. central locking issues with my 96 A6 AVANT 2.5 TDI
    By wall263 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-02-2010, 03:57 AM
