Thread: Worth doing the thermostat, tensioner, rollers & belt etc?
Results 1 to 10 of 13
  1. Worth doing the thermostat, tensioner, rollers & belt etc?
    Sep 2016
    SE London
    Ok....babysitting some relatives dogs next week so have the whole week to work on the car....yay .. thinking what to do.
    I've seen in the service history that in 2012 at 77k miles (90k ago) the water pump was changed so I'm assuming that hopefully a water pump with metal fins was used rather then another plastic one....opinions on that anyone, likelihood?
    The car is an early 08 3.0 tdi q with the ASB engine.
    I can't find anything to say that the tensioner, thermostat, rollers or anything else was changed....forgive my lack of knowledge as I've no idea if there's anything else that the poly v belt revolves around.... The belt looks to be in good condition so that may have been changed during the water pump swap though there's no paperwork to show it.
    Driving the car there's no temperature problems...it reaches a touch over 90 degrees quite rapidly and stays there..Admittedly I'm only going on what the dash board is telling me. There's no unusual sounds coming from the area.
    I have trawled the search function and google but can't find any schedule for when the belt of other things that should be changed...my last car seemed to be great until one day peeeeeeeep and it had overheated busting the head gasket so I don't want a similar thing happening!
    So, what would you guys replace up front? The pump was renewed quite a while ago so I'm not certain if that'd need doing?
    Lastly I don't have Bentley or elsawin so does anyone know of a write up to follow? And having swotted up I've learnt that the front doesn't need to come off (though I may follow gupstergs very good write up as my gaps are atrocious!) and there's a way to move things forward so the bumper's in a service position? How would one navigate that....
    Thanks guys.
  2. Re: Worth doing the thermostat, tensioner, rollers & belt etc?
    Pembrokeshire
    22 Post(s)
    replace the lot, do it everytime regardless.
  3. Re: Worth doing the thermostat, tensioner, rollers & belt etc?
    Sep 2016
    SE London
    Ok, other than water pump, thermostat and tensioner, which rollers should be replaced (I don't know how many their are). And is there anything else on the front that should be replaced? Even the belt if it still looks ok?
    its an early 2008 ASB engine so I'm hoping that my crank pulley will be ok and not suffer from the vulcanisation problem? Can I just check that and maybe if it and some other things seem ok then not worry about replacing?....atm I'm squeezing finances enough as it is.
    Regarding doing the work, can it be done without taking the front off? Maybe just remove the bumper as per gupstergs explanation and put the slam plate bumper in a service position?
  4. Re: Worth doing the thermostat, tensioner, rollers & belt etc?
    Sep 2016
    SE London
    Just had a look at the prices and I guess I'd underestimated what they'd be..... pre owned is looking like a not so bad option! Well maybe not.
    How about this.....the tensioner is original so I'd buy a new replacement I guess, the same goes for the thermostat. But the water pump, rollers and belt.....do they have a replacement time frame? Is there a way that I can give them a thorough inspection and if found to be ok then re used??
  5. Re: Worth doing the thermostat, tensioner, rollers & belt etc?
    Pembrokeshire
    22 Post(s)
    to safeguard a failure, anyone in the trade will recommend a timing belt kit from gates or dayco, or genuine, that will include all rollers tensioners, studs nuts and belt that should be replaced, plus a waterpump and the thermostat. you could risk the pump but be upset if the bearings fail in 5k miles and you have to do the job over again. replace the serpentine belt, its easy cos you have to take it off anyway. remove the bumper and put the rad/lock panel into service.
  6. Re: Worth doing the thermostat, tensioner, rollers & belt etc?
    Sep 2016
    SE London
    Am I correct in thinking that it's not a timing belt but they still call it a timing belt kit, right? So replace the serpentine belt and all the other things.....or else. Yes it's the best thing to do I agree. I suppose it's far cheaper than the discs & pads I just replaced...
    I'll obv need to replace the coolant yes? And would that be with G12 or G13? Any difference? I'm finding difficult in locating a write up on how to put the rad/lock into service once I've removed the bumper....any tips or anyone know of a link that shows how to do that please?
    I've only driven 500 odd miles in this car and it's costing me a fair whack of cash.... hahaha oh well.. Thanks for the help..
  1. Replies: 20
    Last Post: 13-06-2021, 04:49 PM
  2. Replies: 14
    Last Post: 29-06-2018, 07:01 PM
  3. 2.5 V6 tdi serpentine belt tensioner rollers torque specs plese help!!
    By Ricsi168 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2013, 06:47 PM
  4. vibrating noise & belt slip on full lock- serpentine belt tensioner?
    By VtecJunkie in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-12-2009, 04:39 PM
  5. Kinda urgent - replacing belt tensioner, alternator pulley, and belt.
    By farmamick in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2009, 05:00 PM
