Thread: What's the best fuel
  1. What's the best fuel
    Mar 2017
    London
    Hi I've had my 2016 A4 2 litre tfsi sport for a month now and I have always used BP ultimate do you guys think I'd see any performance improvements by switching fuel to say shell V power ?
    thanks in advance
  2. Re: What's the best fuel
    May 2012
    Everywhere
    308 Post(s)
    What's the higher octane ?
  3. Re: What's the best fuel
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by Tm64 View Post
    thanks in advance
    Peoples personal experiences, pub talk etc are hardly scientific. Try different fuels out, and see for yourself.
    Personally speaking I believe a higher octane fuel will only be beneficial under very hard driving or track use.
    Welcome to the forum.
    Ian
    A4 B6 Avant Nogaro Blue
  4. Re: What's the best fuel
    Mar 2017
    London
  5. Re: What's the best fuel
    May 2012
    Everywhere
    308 Post(s)
    Can't see why it wouldn't help mpg as the combustion is better timed .
  6. Re: What's the best fuel
    Pembrokeshire
    22 Post(s)
    the higher the octane the harder it is to ignite the fuel. the harder it ignites, the less you get pre ignition (the fuel igniting before the plug ignites it, also called dieselling, detonation or pinking) therefore the more the timing can be advanced. a modern engine will advance as far as it can and sensors register the knock from detonation. the more its advanced, the faster you can go or the more economical you can be. so yeah, get the v power or use tesco momentum. they are both 99 ron (research octane number). some other so called high performance fuels are 97, and normal unleaded it 95. in the old days it was a start rating, 2 star, 4 star and 5 star, in the days when they added lead to keep valves happy. my old s4 would only run properly on 99, as do most fast engines. at most racetracks you can get 101 ron race fuel..
    0 2 0
  1. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  2. Replies: 3
    Last Post: 05-08-2012, 04:59 PM
  3. Fuel pump issue now Fuel Gauge shows wrong amount
    By neovw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2012, 05:53 PM
  4. Long Term Fuel Trim Add Fuel, Bank1 System too Lean. (17544)
    By boraking699 in forum Bora - 1998 - 2005
    Last Post: 01-07-2009, 03:57 PM
  5. Question 1995 Golf VR6 fuel guage not working + fuel filter location
    By damo1982 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-06-2008, 10:04 PM
