Thread: Actual Pressure problem
Results 1 to 10 of 10
  1. Question Actual Pressure problem
    May 2017
    Istanbul
    Hi guys,
    I have a stage 2 polo gti 6r. My specs are;
    stage 2 software
    dsg software
    bmc air filter
    70 downpipe and 63 varex
    forge dv(blue spring) and wg (yellow spring)
    wagner intercooler.
    I cleaned up the dv and slush the dv and then change the spark plugs ( bkr7eix)
    As i wrote i have actual pressure value if anyone could help me i would be so glad.
    Before wg adjustment;
    http://i.hizliresim.com/ldP8zE.jpg
    http://i.hizliresim.com/nR9aGR.jpg
    http://i.hizliresim.com/1La3nG.jpg
    After wg adjustment;
    https://i.hizliresim.com/j87qzn.jpg
    https://i.hizliresim.com/2r0Ovj.jpg
    How should i solve the problem? Someone said me change your dv's spring with the new one?
  2. Re: Actual Pressure problem
    131 Post(s)
    1976 Post(s)
    Get rid of the DV.
  3. Re: Actual Pressure problem
    May 2017
    Istanbul
    Get rid of the DV.
    I cant actually buy a new one (forge dv).
    I have changed my spring of the dv and then took logs again; nothing changed.
    https://i.hizliresim.com/Np7yqO.jpg
    https://i.hizliresim.com/7q4O8v.jpg
    and i got two faults, should i change the n249 valve or what? Thanks.
    https://i.hizliresim.com/gqBN4R.jpg
    https://i.hizliresim.com/9QO693.jpg
  4. Re: Actual Pressure problem
    131 Post(s)
    1976 Post(s)
    Change the DV back to standard. This is a CAVE engine? Who's software are you running?
  5. Re: Actual Pressure problem
    May 2017
    Istanbul
    This is the CTH engine. I am not sure that have you ever heard the firm but this is EcuFast. When i just bought my car from a friend, I had another software before ( Pschiptuning - 1.8 bar limited ) and i changed the software(ecufast - 1.5 bar limited). Im wondering that if i back to standard DV my car can work stable with 1.5 bar limited?
  6. Re: Actual Pressure problem
    131 Post(s)
    1976 Post(s)
    The CTHE is the same as the CAVE, the only difference is the ECU map. You don't need a different diverter valve to handle a little more boost, aftermarket diverter valves cause so much trouble it's daft and these twin charger engines are temperamental things. We did a head rebuild on one in a Golf 5 GT last week, totally worn out exhaust valve guides at 70K miles! These downsized high boosted petrol engines are a nightmare waiting in the wings. Even VW have had to say lets stop this, no more.
    0 2 0
  7. Re: Actual Pressure problem
    May 2017
    Istanbul
    Yeah, i knew the difference. I asked my friend and he said me "i bought the dv and wg from second hand and i gave the standard dv to you as well" so i ll put in the standard dv and then take log again, if actual pressure values would be normal should i go on by standard dv? Btw, my car is at 25k miles. You are completely right or maybe i should drive and be happy with the actual pressure problem
  8. Re: Actual Pressure problem
    131 Post(s)
    1976 Post(s)
    There is nothing wrong with extra power, it would be good to find out why it is unstable.
  9. Re: Actual Pressure problem
    May 2017
    Istanbul
    Thank you so much for your help if i find out the problem i ll let you know.
  10. Re: Actual Pressure problem
    May 2017
    Istanbul
    Hi again, i changed n75 valve and then log again; I think my acceleration was faster than before but the logs doesnt say samething
    OR CHECK here;
    first log (3th - 4th gear)
    second log (3-4-5th gear)
    First log;
    log11.csv - Google Drive
    Second log;
    loog22.csv - Google Drive
  1. Service and the actual intervals
    By JayA3sline in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-04-2014, 08:34 PM
  2. Question actual mpg s-line 170 and 143??
    By the-stigg in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-07-2013, 07:20 AM
  3. High Fuel Pressure specified vs actual
    By busandcamper in forum VCDS - Help Requests
    Last Post: 08-12-2012, 12:26 AM
  4. Please Help 2003 A4 2.5 TDI problem speedo 15mph faster than actual speed?????
    By bigtoe22782 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-04-2011, 08:26 PM
  5. Maf actual 430...maf specified 250?! any ideas?
    By ALIN in forum Golf MK4 - 1999 - 2004
    Last Post: 16-06-2010, 10:44 PM
