Thread: Our Sharan is a swimming pool........
  1. Our Sharan is a swimming pool........
    Jul 2006
    Please help, Our lovely Sharan is leaking rain water in the passenger side, it seems to collect in a tray at the top of the bonnet and when we drive it floods in, and falls down behind the glove compartment, when I say a leak I mean it is like turning a tap on.
    We need to find out how it is getting in and how to seal it. The leak seems to have become worse.
    Thanks... Ziggi.
    Feb 2004
    Yorkshire
    49 Post(s)
    Could be leaking through the pollon filter... has this been changed recently? If it is not put back or sealed correct this can cause this to happen.
    STuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
    Aug 2006
    could be you have blocked drain holes which are located at either end under the windscreen. Try flushing out with a hose. Quite difficult to reach the area so best to put the wipers on then switch the key off at mid travel, this stops the wipers in the vertical position and allows easier access to the drain holes. I had the same problem and now flush out the drains every six months or so.
    Jul 2006
    Thanks for the advise, will let you know what works.
    Ziggi.
    Jul 2006
    Hi red,
    You were right it was blocked drainage, it has solved a very big problem.
    Thanks again..
    Ziggi
  6. now check ecu under seat?
    Aug 2006
    Berks,Hamps, Surrey corner
    Hi, does your sharan have the alarm/windows central ecu in the floor under the passenger front seat? if so make sure it wasn't water damaged!
  1. VW Sharan
    By mike in forum Touran - Sharan - Caravelle
    Last Post: 14-12-2007, 10:12 AM
  2. Which Sharan?
    By happy2 in forum Chat - Anything with wheels
    Last Post: 10-06-2007, 01:23 PM
  3. MkIV Golf swimming pool
    By bgvw in forum Golf MK4 - 1999 - 2004
    Last Post: 14-02-2007, 06:57 PM
  4. sharan
    By vw007 in forum Touran - Sharan - Caravelle
    Last Post: 24-09-2006, 10:59 PM
  5. VW Sharan Sat Nav
    By efiokcas in forum Touran - Sharan - Caravelle
    Last Post: 15-03-2006, 10:01 PM
