Thread: '00 Golf 1.8T Engine in a B5
  1. '00 Golf 1.8T Engine in a B5
    I have a question about engine transplant.
    I have a timing belt victim 2000 Passat 1.8T, and access to an engine from a 2000 GTI Golf. North American cars which I am not sure if that makes a difference.
    I am wondering if I could drop the golf engine in the Passat. I Realise there is a layout difference. one logitudinal one transverse but are the block different?
    i also know that even if it works I need to use the passat oil pan and turbo but what about the rest ?
    I just founf out that the engine in the Passat is ATW
    Thanks for shedding some light.
  2. Re: '00 Golf 1.8T Engine in a B5
    Gwent
    I can't answer your question exactly. But I have fitted a longitudinal Audi 2.0 16v engine (6A) into a B3 passat 16v (9A). The heads were the same, the blocks were nearly identical, the longitudinal Audi engine used a bracket/brace to connect to the lower part of the gearbox bellhousing. The transverse engine does not use this, so the block has less 'meat' around the gearbox end of the sump, there are no mounting points for this bracket and not enough metal there to drill your own.
    Another difference is the spigot bearing in the back end of the crankshaft. The transverse engine does not use one, but it appeared that the crank had been bored ready to accept the bearing.
    The sumps were different shapes, I chose to swap them over, the oil pick up pipes were also different so I swapped these too.
    I had to use all of the transverse type manifolds and brackets, eg engine mountings alternator hanger, power steering pump hanger etc.
    I don't know if the same differences exist between the 1.8t engines, but I guess most of them will?
    Last edited by scotty33; 25-10-2007 at 09:35 PM. Reason: entered in error, before finishing post - Doh!
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: '00 Golf 1.8T Engine in a B5
    I was looking for a direct drop in with maybe a swap of accessories but it seems like they are not the engine really!!!
    thanks for the input.
  4. Re: '00 Golf 1.8T Engine in a B5
    Gwent
    Ah, sorry if the news was bad, did not mean to put you off, just point out the issues. To be honest, if you are up to changing the engine, you can do the swapovers, it just takes some time. The only potential issue that you won't be able to solve, is the bellhousing bracket. I have heard of longitudinal mount cars being fitted with transverse type engines, I have not heard of any issues with doing this?
    I did forget to mention that the flywheel/clutch was also different...
  1. VW Golf 1.6 FSI Engine noise
    By David Farmer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2009, 11:10 AM
  2. VW Golf Engine Cut Out
    By burnsie20 in forum Archive posts
    Last Post: 04-09-2007, 06:18 PM
  3. AHF Golf engine
    By dreamworx in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-03-2007, 10:15 AM
  4. Engine Oil for Mk 4 Golf
    By Reet in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-12-2006, 02:28 PM
  5. Engine failure on Golf GTI - Help
    By golfscot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-05-2006, 12:46 PM
