Thread: Golf 1.9 TDI tapping noise
  1. Golf 1.9 TDI tapping noise
    Jul 2007
    I have a 58 plate 1.9 TDI Golf 58k miles ( its a 110Hp blue motion)estate manual which started tapping. I have replaced the camshaft and hydraulic tappets which all sound fine at idle but at about 2500rpm it sounds as if the tappets are really noisy.
    I am very familiar with these engines and worked on them for years but never had this problem. I'm thinking that it may be something other than tappets but have never heard this on a PD engine before.
    Anyone had any similar issues?
    Thanks for any help.
  2. Re: Golf 1.9 TDI tapping noise
    134 Post(s)
    2020 Post(s)
    Could you PM me the cars reg?
  3. Re: Golf 1.9 TDI tapping noise
    134 Post(s)
    2020 Post(s)
    There is a known problem with the boost control valve that can cause rattling noises to be transmitted through the bulkhead, if you dismount the valve and then try it the noise may go and then there is an updated pipe 03G 129 808 C which solves the problem but you noise gives the impression of being too sharp for that and a similar problem can come from the EGR valve where a restrictor valve has to be added to the feed line, 03G 131 050. Without hearing the noise first hand it is all I can think of. What make of cam and lifters did you fit with the part numbers if possible? Did you rest the injector lever clearances?
  1. Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    By keawe in forum Golf MK4 - 1999 - 2004
    Last Post: 09-02-2017, 02:21 PM
  2. Important VW Golf GT TDI MK4 Knocking/Tapping Noise
    By squashy1982 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-05-2014, 11:26 PM
  3. Please Help Golf GTi 2.0 MK4 tapping noise
    By j_caie in forum Golf MK4 - 1999 - 2004
    Last Post: 14-10-2009, 08:54 PM
  4. Golf MkV 1.4TSI - Climate Control Tapping Noise / Not warming up
    By nnchokshi in forum Golf MK5 - 2004 - 2009
    Last Post: 18-09-2009, 12:40 PM
  5. Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    By C_jam01 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2008, 10:01 PM
