Thread: 2006 2.0 TDI - Engine Hiccuping
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: 2006 2.0 TDI - Engine Hiccuping
    132 Post(s)
    1979 Post(s)
    Could you do an up to date scan and post it plus PM me your VIN?
  2. Re: 2006 2.0 TDI - Engine Hiccuping
    Jun 2013
    Kent
    This was from Monday - scanned and cleared before my journey to work:
    Monday,08,May,2017,08:01:29:05031
    VCDS Version: Release 15.7.1 (x64) Running on Windows 10 x64
    Ross-Tech: Home
    Address 01: Engine Labels: 03G-906-018-BKP.clb
    Control Module Part Number: 03G 906 018 CE HW: 03G 906 018 CE
    Component and/or Version: R4 2.0l PPD1.5 G 9384
    Software Coding: 0000072
    Work Shop Code: WSC 00028 028 00001
    VCID: 6ADC5A87456C4E6EE3-803E
    5 Faults Found:
    005186 - Potentiometer for EGR (G212)
    P1442 - 006 - Signal too High - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 1
    Fault Frequency: 12
    Reset counter: 40
    Mileage: 134343 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:48:58
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    0.00 %
    Battery Volts: 1.0 V
    Mass Air / Rev.: 0.0 mg/str
    000257 - Mass Air Flow Sensor (G70)
    P0101 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 134103 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:57:28
    Freeze Frame:
    RPM: 2016 /min
    Torque: 0.0 Nm
    Speed: 105.0 km/h
    Temperature: 18.0°C
    Pressure: 1171.5 mbar
    Text: 164 kg/h
    (no units): 0.78
    000550 - Throttle Pedal Position Sensors (G79)/(G185)
    P0226 - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 39
    Mileage: 134344 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:50:00
    Freeze Frame:
    RPM: 704 /min
    Torque: 136.0 Nm
    Speed: 43.0 km/h
    0.00 %
    Voltage: 14.24 V
    Voltage: 1.19 V
    Voltage: 0.94 V
    005000 - Control Module Malfunction - DBW Throttle Monitoring
    P1388 - 006 - - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 134344 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:50:32
    Freeze Frame:
    RPM: 1216 /min
    Torque: 32.0 Nm
    Speed: 43.0 km/h
    0.00 %
    Voltage: 0.10 V
    Voltage: 0.94 V
    Voltage: 14.13 V
    001603 - Sensor Reference Voltage A: Circuit
    P0643 - 006 - High - Intermittent
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 38
    Mileage: 134344 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:50:32
    Freeze Frame:
    RPM: 1216 /min
    Torque: 32.0 Nm
    Speed: 37.0 km/h
    Voltage: 5.12 V
    Hex Value: 0x0000
    Voltage: 14.13 V
    Voltage: 14.13 V
    Readiness: N/A
    Then got this from this mornings journey:
    Monday,08,May,2017,08:49:21:05031
    Ross-Tech: Home
    3 Faults Found:
    P1442 - 006 - Signal too High - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 40
    Mileage: 134358 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:01:58
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 2.0 km/h
    0.00 %
    Mass Air / Rev.: 501.4 mg/str
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 39
    Mileage: 134362 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:10:23
    Freeze Frame:
    RPM: 576 /min
    Torque: 144.0 Nm
    Speed: 11.0 km/h
    0.00 %
    Voltage: 14.13 V
    Voltage: 0.66 V
    Voltage: 0.68 V
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 134362 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:10:43
    Freeze Frame:
    RPM: 1344 /min
    Torque: 16.0 Nm
    Speed: 11.0 km/h
    Voltage: 5.20 V
    Hex Value: 0x0000
    Voltage: 14.13 V
    Voltage: 14.13 V
    Readiness: N/A
  3. Re: 2006 2.0 TDI - Engine Hiccuping
    Jun 2013
    Kent
    Changed the Mass Airflow Sensor back to the original (changed it when I bought the car, as there was a fault code for it, but it turned out to be a loose pipe), and now the stuttering *seems* to have gone.
    However, still getting all the other codes on a cold start. If I clear them all, and run the car after the engine is warm, they don't seem to come back (until the next cold start). Have tried leaving the battery disconnected while I was at work, but that did nadda.
    Done an auto scan, and got all these faults!
    Data version: 20150904
    Ross-Tech: Home
    Wednesday,10,May,2017,08:57:45:05031
    Gateway Installation List: 3C0 907 530 C
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
  4. Re: 2006 2.0 TDI - Engine Hiccuping
    Jun 2013
    Kent
    Changed back to the original EGR and all faults gone o.O
  1. Thoughts on a 2006 2.4 engine?
    By mrsweet1991 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-12-2016, 12:36 AM
  2. 2006 Polo BKY Engine Help
    By Onefut in forum Polo - Derby - Lupo - Fox
    Last Post: 06-01-2016, 02:37 AM
  3. Engine misfire(2006 A4 petrol)
    By BTW in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-06-2014, 12:08 PM
  4. Please Help A3 Tdi 2.0 170 2006 ENGINE COVER
    By hawkes77 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-10-2012, 08:59 AM
  5. 2006 A6 Engine Required?
    By Fitz76 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-09-2010, 05:12 PM
